gasket and torqueing order
Old Oct 25, 2007 | 08:52 AM
blue72regency's Avatar
i purchased an alluminum edelbrock performer intake manifold. summit also sold me on the idea i needed an intake manifold gasket for this. they said something about it being aluminum and this aftermarket manifold might work better with this other gasket when i'm using the valley pan. i just bought a vally pan as well.
so.. i use the vally pan AND this intake manifold gasket both?
another question. i'm putting the heads back on and want to know if anyone had the order you torque the bolts back into the heads/block?
i also want to do away with the non funtioning cruise control contraption thats fixed to the throttle cable area. is there anything/ suggestions i need to know about doing away with this.
i also want to do away with all the EGR stuff and just add breathers to the valve covers. i just purchased the little covers for the carb from summit and hope that takes care of any open ends left from eliminating the emmisions stuff.
Old Oct 25, 2007 | 12:38 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
http://www.edelbrock.com/automotive_.../3000/3711.pdf
Edelbrock has a recommended gasket for all of their intakes, but I just use the Turkey tray and a bunch of sealant.
If you end up using a new tray, you will have to cut an opening for the exhaust port underneath the carb.
Old Oct 25, 2007 | 12:58 PM
CHRISH8846's Avatar
Most will only use the turkey tray with the factory cast iron intake,everyone that I know of uses seperate intake gaskets and end seals or rtv to seal the ends of the manifold,alum and the steel turkey tray seem to be very leak prone.Some cut the intake gasket part off the turkey tray off and use the valley part as a valley cover and some buy aftermarket trays to do the same ie Mondello's.
Old Oct 25, 2007 | 01:02 PM
Do a post search of this forum...
TURKEY TRAY
You will find plenty of ideas.
Let us know what you decided on
Old Oct 25, 2007 | 01:05 PM
i like that idea. maybe i could cut and use the valley pan part of the new vally pan and then use the edelbrock gaskets for the intake manifold part???
Old Oct 25, 2007 | 02:29 PM
CHRISH8846's Avatar
That is correct
Old Oct 25, 2007 | 02:49 PM
don71's Avatar
same but different
Here is a pic of what you are thinking of doing.....this is what I do....
Old Oct 25, 2007 | 04:58 PM
dar83501
Guest
Posts: n/a
If you want to kill your EGR, there's a quick and dirty way to do it...Although I don't recommend doing it if you aren't sure you know what you're doing it.
Find your two EGR pipes, remove them from the engine, and bend one end (the end that doesn't go on the block) over twice, and crimp the end shut. If you have a welder, I would bend them over and weld that end shut. I don't have one, nor a heat torch, so I used a vice to bend them over and crimp them shut (I lost about five pounds from manhandling the vice). Make sure nothing will get by them. Even if it looks shut make sure nothing will get by it, or it'll leak. Then build a blockoff plate for your EGR valve (A chunk of metal, I wouldn't say more than a 1/4 inch thick) and get some high temp sealant to seal the plate to it. Cut the Blockoff plate to fit over your EGR valve. Make sure it's a bit bigger than the EGR itself, of course.
I've only done this once, and the pipes leaked a little. Oh well, wasn't my car and I was doing all the work for free :|
Although..I'm sure somebody has a more efficient way to do it. hehe.
Bobac455
Dec 4, 2013 09:23 AM
aussiemobile
Feb 15, 2013 07:31 AM
harry k
Nov 21, 2012 08:54 AM
dallasite21
Jun 20, 2010 05:37 AM
Sixoh
Aug 8, 2006 05:11 AM
