G block markings
Absolutely nothing. Contrary to what you may read on the web, the "F" numbers on the back of the block do not indicate nickel content. They simply refer to different, minor changes to the casting configuration. The are meaningless.
I merged your identical threads. As always, it is neither necessary nor in your best interest to post the same question in multiple threads. You'll get better information if all responses are kept in the same thread so everyone can spot and correct potential misinformation.
