Shopping For A Valve Job
Old Dec 27, 2015 | 02:05 PM
VinMichael's Avatar
What are good questions to ask when shopping machine shops for a valve job? I have a new set of Procomps and new set of valves and springs, chose a cam, etc. Shooting for 450 hp 455 30 over around 10:1 compression.
One shop quoted me $200 the other $400.
Old Dec 27, 2015 | 02:17 PM
cutlassefi's Avatar
Ask what each one will do for those prices.
Old Dec 27, 2015 | 02:38 PM
VinMichael's Avatar
Thanks. I can ask them that.
Old Dec 27, 2015 | 06:54 PM
83hurstguy's Avatar
Some typical questions would be if they'll actually measure valve stem to guide clearance on all valves, what equipment they'll use to perform the valve job, how many angles they'll use, if they'll measure your valve spring installed height and check the valve spring load, etc...
Old Dec 30, 2015 | 02:00 PM
Warhead's Avatar
What kind of valve seals do they use? (hint: hopefully positive wiping viton/ rubber seals)
Can they GIVE YOU all the valve stem heights and spring installed heights written down for EACH valve?
3 angles? 3 on the intake is a must.
Stem to guide clearance.
25-30 deg back cuts on intake?
Find out how much extra it is, for these extras.
Old Feb 15, 2016 | 04:31 PM
VinMichael's Avatar
So it looks like they are using positive wiping seals. They are measuring the spring heights and requested the cam card to do so. I guess they had to shim the valve springs somewhat.
I will hear back from him with what they find.
Fliplander
Jan 6, 2026 02:55 PM
MDchanic
Paint
30
Jul 7, 2012 10:07 AM
Olds_71_442
Apr 1, 2012 06:11 PM
jslabotsky
Aug 15, 2009 10:30 AM
