Fragged a 455
Old Oct 13, 2008 | 10:00 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Fragged a 455
Fragged my 455 at Cordova this weekend. Checked Oil pressure with a portable gauge before racing and it was great. 4 passes later the engine was cranking slow. Thought the starter or battery cable got fried. When I pulled a plug and turned it over with a breaker bar it was a horrifying feeling. Slower than dirt, with a 3 ft breaker bar. After the motor cooled it wouldn't turn at all.
I tore it down and even with all the caps off the mains and rods it STILL wouldn't turn.
Turns out the #3 rod bearings slipped underneath one another and welded themselves together. Then welded the #4s to it as well. I just had 1 solid 1.5'' ring welded around and to the crank. It was a total loss. Rods, crank, everything... JUNK. The block seems ok but you can't eyeball machinist tolerances.
It was running 14.6 in the 1/4 with a stock g headed motor, th350 and 7.5 3.08s Shifting at 5100. Oh well, At least it wasn't my 350.
Weirdest thing ever. No knocks, noises, rpm fluctuations, nothing. Ran strong every pass till it started cooling down.
Going back to 307 power this winter
Old Oct 13, 2008 | 10:42 AM
Run to Rund's Avatar
#3 and 6 rod oil feeds come out at the wrong angle. At some rpm vs. oil pressure, the oil doesn't flow out. For at least 35 years people have chamferred the oil holes heavily and run a trough about 1/8" wide and deep in the direction of rotation at those journals. Run heavy wire through the oil feed holes and you will see what I mean, and what direction to run the troughs.
Old Jan 30, 2009 | 11:41 AM
I put another big block in. It's a wimpy 72 motor though. I'm gonna have to do a decent amount of work on the heads to make it un-slow.
The 307 only had 75 psi compression in the # 6 cylinder, so It's in the junk pile now too.
Old Jan 30, 2009 | 11:45 AM
Oldsguy's Avatar
Past Administrator
You know the same thing happened to the 455 in my '76 Regency, except I wasn't racing it. Those big blocks seem to go without warning, even though they go forever, and ever, and ever....
Old Jan 30, 2009 | 11:52 AM
f-85's Avatar
Not in my garage! NO MORE 307S! Did you pick up that 69 455? Now thats something we can work with!
Old Jan 30, 2009 | 12:44 PM
Lady72nRob71's Avatar
OUCH!
That is a painful story indeed... Do the 350's have any known weaknesses like that??
What might have happened if you hadn't shut it down??
Hope you get it running again, only better than before!
Old Jan 30, 2009 | 01:20 PM
citcapp's Avatar
Ouch that hurts even from here in Bothell. Crazy that there was no warning. Do you have an oil guage at the dash as well and what was the reading during the cool down between passes
Old Jan 30, 2009 | 01:36 PM
f-85's Avatar
No he didnt. now he does
Old Jan 31, 2009 | 10:14 PM
88 coupe's Avatar
Junior Member
I put another big block in ........
Shift this one at 4500 RPM.
Norm
Old Feb 4, 2009 | 12:54 PM
Techmaven's Avatar
Rocket Veteran
Norm
Agreed. I don't know what cam you were running, but a basically stock 455 is all done before 5100.
My stock 69 442 400/325 auto/3.23 ran best left in drive 14.5 at 96 shifting at about 4700rpm.
Old Feb 8, 2009 | 05:29 PM
smcurro's Avatar
Does this problem exist for 425 crankshafts as well? How about 330/350 cranks?
Old Feb 9, 2009 | 04:27 AM
wolfman98's Avatar
Captain of my ship
bearings
My first good car was a 66 Chev Impala SS 2 door hardtop with a 283 and the bullet proof two speed glide tranny. I was running it on the highway about 70 mph and stepped on it . When it hit 90 everything just stopped. It was like the motor shut it self off and I ended up coasting to a stop on the side of the road. turned out that one of the crank bearings slipped in behind the other and jammed up to stop the motor dead in it's tracks.Ended up that was only damage and just had to turn the crank and get new bearings. Then I sold it and put in a stock 325 horse 327.
Old Feb 9, 2009 | 11:39 AM
Originally Posted by wolfman98
My first good car was a 66 Chev Impala SS 2 door hardtop with a 283 and the bullet proof two speed glide tranny. I was running it on the highway about 70 miles per hour and stepped on it . When it hit 90 everything just stopped. It was like the motor shut it self off and I ended up coasting to a stop on the side of the road. turned out that one of the crank bearings slipped in behind the other and jammed up to stop the motor dead in it's tracks.Ended up that was only damage and just had to turn the crank and get new bearings. Then I sold it and put in a stock 325 horse 327.
Yeah, that's pretty much what happened to me as well. Except there was no saving that crank.
dp442
Feb 15, 2011 04:22 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
SKINNY IL
May 14, 2010 07:12 AM
egknz
Jul 21, 2009 01:09 PM
gearhead1218
May 26, 2009 05:22 PM
