Forged Piston Choices
400hp yes. 500hp maybe. I've seen stock rods live at 600hp and I've personally had stock rods not stay round at 450hp. IMO for anything over a stock rebuild new H-beams are a no brainer.
x 2.. the weight savings alone on rotating assembly is unbelievable..when mine was done the WEIGHT difference in stock rods and old TRW replacement pistons was right at 290 grams..they had to drill some big holes in crank to balance it all out …
....Just my two cents worth.
Definitely looking for reliability...
I would like to keep the engine stock appearing w/ some grunt. The car is a broadcast card documented 70 W-30 w/ non numbers etc...
Here are a few items I would like to keep but I'm assuming these could be barriers too...
I would like to use the stock valve covers, factory intake & a Rochester carb...
Currently looking at the following combo...
Wiseco .03 w/ Eagle rods H rods
What compression should I look to target w/ iron heads...
Aftermarket rods.
Hydrologic Roller cam (lots of benefits).
Johnson roller lifters.
HS roller rockers (will fit under stock valve cover with baffle mod).
Good aftermarket piston CP, Diamond ect.
Compression between 10 and 10.5 depending on cam choice.
Internal balance.
Don't order pistons until head and block work is corrected and verified.
Internal balance.
Yes, I should have been more specific.
I'm like to clean up the cylinders and square the block to see where she stands. Check head surfaces and mill if needed and CC. Determine compression ratio based on piston/rod characteristics, head CC , in hole depth and gaskets being used ect. Order pistons and do final bore for clearance and double check all the above and balance
I am sure you have much more experience than I. I have seen my share of shady machine shop work.
All I was trying to say is, don't go off half cocked buying pistons without knowing specifics and having a plan.
Lots of ways to skin this cat..really all depends on what your comfortable with on the expense side. Roller cams cost quite a bit more than flat tappets etc. Are they worth it? That depends on what you’re gonna do with the car and if you’re OK with spending the extra money. Everybody says flat tappet cam’s have flattened lobe issues, however, if you buy a good quality, solid brand cam, and use the correct break in oil, Have the distributor and everything set up correctly so it fires up on the first crank then you should have no problem. It really depends what you want to do there’s really no answer that’s wrong.
