Fel pro Timing cover gasket sleeve N seal?
![Question](https://classicoldsmobile.com/forums/images/icons/icon5.gif)
What is the difference between this
![](http://s7d5.scene7.com/is/image/CanadianTire/0174077__1?$medium$&defaultImage=image_na_EN)
Fel-Pro Timing Cover Gasket Set
or this???? What is Sleeve And Seal? and is it good or bad?
See below
![](http://s7d5.scene7.com/is/image/CanadianTire/0175655__1?$medium$&defaultImage=image_na_EN)
Select Store
Select Store
In Stock online
Out of stock online
Please select a store for inventory status. (Select Store)
Please select Style/Size to add item to your Shopping List
Please select Style/Size to view pricing and inventory information
joepenoso
See below
Select Store
Select Store
![](http://www.canadiantire.ca/media/images/global/automotives/available_in_store.png)
![](http://www.canadiantire.ca/media/images/global/automotives/ask_store_for_detail.png)
- Product Number : 17-5655-4
- Manufacturer Part Number : TCS45270
- Brand : Fel-Pro
- Comments : w/SLEEVE 'N' SEAL
joepenoso
I would think the sleeve refers to the steel sleeve that is pressed onto the harmonic balancer to correct worn grooves from leaking oil. I have used many of them in the past and when installed correctly, they work great.
I agree with edzolz. They make up for the groove you find in the balancer from rubbing the seal. But the photos show gaskets for 2 different engines. (generic pics?)
I have used the sleeves for many different types of seals. CR seals called them speedy sleeves.
Didn't we just have this discussion in another thread? If the motor is sound, there's nothing wrong with replacing just the cam and lifters. This is done frequently.
Back to the O.P.'s original question, the upper gasket set doesn't fit an Olds motor. Unfortunately, if you Google the FelPro part number (TCS13417), even FelPro claims this fits an Olds diesel. They would be wrong. TCS45270 is the correct timing cover gasket set for EVERY 1964-1990 Olds V8 made (as always, excepting the 1964 394 motors).
The "sleeve and seal" means that the kit includes the thin stainless steel repair sleeve that slides over the balancer to cover any grooves that might have been cut by the front main seal. You want this.
I am answering this on 2 threads.
Instruction for sleeve here. http://www.skf.com/binary/12-61918/TT08_021.pdf
The only other thing I do is chill the dampner and heat the sleeve on a light bulb then install.
MDchanic
June 1st, 2014 08:09 PM
70Cutlass_408
August 17th, 2011 12:08 PM
