Fan
Old mushed motor mounts can cause the front of the engine to droop.
A bent or distorted frame (frequently caused by jacking up in the wrong place) can raise the trans, again lowering the front of the engine.
An improperly attached shroud or bent tabs for the shroud or bent lower bar on the core support can raise the bottom of the shroud.
An improperly installed core support, incorrect core support rubber mounts (if they've been replaced), or bent frame horns (from an accident) can also change shroud location.
I had an aftermarket Energy Suspension poly transmission mount that was holding the transmission up too high forcing the engine down which caused the same issue. Switched to a rubber mount and it fixed it.
Eastflorida
Jul 21, 2017 01:23 PM
