F head question?
Old Jan 6, 2013 | 08:38 AM
jensenracing77's Avatar
F head question?
Did F heads have one side heat riser blocked off or did someone fill this? It don't want to come out but it almost looks like a plug from the inside. If it should not be there would it hurt to leave it in on only one side? These are the original set to my car so i don't want to try something i shouldn't.
On another note: I see many roller rocker kits need the holes drilled for a bigger stud. I am not going to do that to a set of F heads. With a roller cam and the stiffer springs, will the smaller stud hold up?
100_1145.jpg?t=1357490174
Old Jan 6, 2013 | 11:18 AM
stevengerard's Avatar
X2
Old Jan 6, 2013 | 12:33 PM
2blu442's Avatar
Sounds like you've got your answer Eric, but X3 on the head being filled by a previous owner.
John
Old Jan 6, 2013 | 01:21 PM
i knew about the smaller studs but i was wondering if the higher spring pressure for a roller cam (or other factors) would be to much for them. It will not be a crazy build and likely be under a 6000 RPM engine so I feel like they would be ok to use but don't want trouble either. I will look closer to the head. If i can get it out i will but if i can't will it affect anything only having one side plugged?
Old Jan 6, 2013 | 01:23 PM
Originally Posted by joesw31
Also, like the small pic of your w-27!
LOL, i didn't notice that till now. good eye
Old Jan 7, 2013 | 07:36 AM
MX442's Avatar
Somewhere I read, don't remember the source, that the smaller studs are good for 350 lbs spring pressure. Should be just fine for a street roller cam.
http://www.compperformancegroupstore...Category_Code=
young olds
Jun 3, 2014 08:13 PM
Olds Scott
May 29, 2013 08:15 PM
Ragtopw1972
Oct 18, 2012 08:19 AM
CLcutlass
Aug 21, 2011 06:25 PM
bigcountry1009
Apr 14, 2007 09:25 PM
