F casting on a 1972 455?
Old Apr 19, 2009 | 04:40 AM
import extermination's Avatar
ive found a 72 455 block with the "F" casting
is that actually possible? and if so, would it be worth spending 700 canadian?
Old Apr 19, 2009 | 05:49 AM
2blu442's Avatar
I'm not sure how that translates into US dollars, but is it a good runner? I know availability will set the price, but for a rebuilder I would hope you could find one closer to the $350-400 mark. John
Old Apr 19, 2009 | 06:26 AM
Originally Posted by import extermination
ive found a 72 455 block with the "F" casting F
What exactly do you mean by "F" casting? That the casting number is 396021 F, as opposed to 396021 FA? And how did you determine that it's a 1972 block, from the VIN derivative? In any case, lots of 1972 455 castings were F castings so it's not particularly rare. It's also the same as every other 1968-1971 455 block. As for what it's worth, is this a bare block, short block, long block, or complete motor? In my opinion, a bare block that needs machine work is worth about $100 USD. I've recently bought complete short block cores for that kind of money. $700, even CDN, for a bare block is crazy.
Old Apr 19, 2009 | 06:34 AM
2blu442's Avatar
Oops! I need another cup of coffee as I missed the point of this being just a block. Check out the link below, a 455 runner with aluminum intake and extra pair of C heads $300 on the Seattle/Tacoma Craigslist. If you have a vehicle that could haul it home it might be worth a road trip!
http://seattle.craigslist.org/oly/pts/1128467774.html
If the advertizement is accurate I would consider this a good deal so if you have the ability to get it you might want to move on it quickly. John
Old Apr 19, 2009 | 11:46 AM
by F casting i ment on the back of the block, where olds would put F,F0,F1....
this one just has a F
Old Apr 20, 2009 | 02:08 PM
the casting on the front is 396021F, but on the rear there is an "F" and a 68
Old Apr 20, 2009 | 07:41 PM
What year does the VIN derivative indicate the block is? In any case the "F" numbers do not indicate anything magical about the metallurgy of the block, contrary to belief.
Daverd
Dec 26, 2014 12:35 PM
Al2011
Apr 18, 2014 11:14 AM
Nickyloves442s
Oct 24, 2012 04:55 PM
bobb
Jan 4, 2011 09:07 PM
olds4life
Aug 6, 2009 01:45 PM
