Exhaust Question????
This might be a stupid question but Im no expert when it comes to performance .....Im pretty novice to be honest.
So Ive decided to purchase a set of headers and im on a tight budget!!
The headers are 3'' and my car has all new exhaust from front to back and its 2 1/4 and new flowmasters .....is it pointless to by headers and reduce it down to 2 1/4????
You need to tell us a little bit about you engine. Unless you are running a lot of engine, no way you need 3" headers. Bigger is not necessarily better. There are experts on here who are a lot better versed on headers than I am but they will not be able to give any good advice without knowledge of your engine. By the way, it may take a little longer than an hour and eleven minutes for somebody to reply.
Ok the headers are flowtech part# 11154FLT going on my 71- 455....mild cam/performer intake and i think where the exhaust pipe joins on is 3"....so I can just reduce there to 2 /14 into my exhaust pipe???
Thanks for the help guys ...like I said Im pretty novice when it comes to some of this stuff!!
Let's back up. When you say 3" headers, I assume you mean the collector diameter. This is normal. Headers are designed to be run open at the track, hence the 3" collectors. Every header comes with reducers to neck down to a smaller exhaust system size for street use. Personally, I'd use 2.5" instead of 2.25" for the exhaust system, but it will work. You will suffer a little increased backpressure from the smaller pipes.
The whole rerason for headers is too speed the flow of exhaust from the engine. Generally speaking, the larger the engine the larger the tubes. On a smaller engine, or mostly stock engine, smaller tubes will build more exhaust velocity, to get the gasses away and allow the engine to breather better and suck in more fuel. Too large a tube and the exhaust will just sit there. So what size are the tubes, not the collector?
I think someone already said that bigger isn't better, necessarily.
Most exhaust companies offer header collector flanges that go from 3 inch to 2 1/2 (or 2 1/4) that are about 10 inches long. Much better flow than the huge drop in diameter the shorter flanges offer.
2blu442
March 7th, 2014 06:09 PM
atkinsom
May 29th, 2013 06:39 PM
65OldsDelta88SuperRocket
October 27th, 2011 09:16 PM
