exHaust question
Old Sep 19, 2007 | 08:00 PM
punishercarr's Avatar
425 Member
exHaust question
I had a question for all guys, I getting a dual exhaust system on my 1965 Olds but I was told by the Throton Reproductions that you can only run duals on one side as the passenger side is to be capped off. My engine guy is trying to run both passenger and driver's side exhaust directly from the engine, is this posible?
Old Sep 19, 2007 | 10:42 PM
88 coupe's Avatar
Junior Member
Not only possible, it is how it was normally done from the '30s through the '70s.
Crossover (a separate system) pipe is removed, and its flange, on the existing exhaust (your right) side, is capped. The new exhaust is connected to the opposite (your left) crossover flange.
The "heat riser" valve should either be locked in its open position, or removed
Thornton Reproductions sells exhaust manifolds. Would you expect a "salesman" to tell you about an alternative to purchasing his product?
Norm
Old Sep 21, 2007 | 09:29 AM
425 Member
Thanks Man,
Jonathan
Norm
Old Sep 28, 2007 | 10:31 AM
frdmftr's Avatar
Freedom Fighter
I have the dual setup that 88 Coupe refers to in his reply. Its in my 67 Delta 88 convert w/425ci. The dual is created by removing the crossover pipe, having a new pipe built from rt manifold, follow crossover pipe route and run aft alongside the Lt pipe. The crossover flange is plugged with a piece of pipe flange with the end capped and welded. The stock clamps and new gasket are used. The pipes 'split' in center of car, cherry bombs installed just before rear axle. Usual exit out rear (see pics).
Best solution would be to find a correct dual manifold setup. I know Lt side is available, Rt seems to be very rare (don't know why). If you run Rt side directly down and aft, you also need a shift rod that has a 'half-moon' relief for the pipe. There is a post somewhere here that had the info. Don't know if it was slavaged after the servers crashed.
Good luck.
Old Sep 28, 2007 | 05:18 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
What ever happened to good ol' flipping the manifolds upside down and running pipes out of the hood.
Old Sep 28, 2007 | 06:38 PM
YEAH! You could run the exhaust out of the hood like the cars on Mad Max. That is AWSOME!
Actually, I know Oldsguy ended up putting true duals on his 69 Delta 88 that he had. We found a driver's side manifold from a Toronado and cut the rear dump off of it. Then we turned the dump around so the manifold dumped up instead of down and had it welded back together. Then we had the passenger side manifold welded up instead of putting a cap on it. MUCH BETTER and looks better too! Once the project was done an exhaust shop ran duas from each side of the engine all the way back. If you purchase a manifold from Thornton I believe they will allow you to run duals without doing any modifications. The manifolds are made to clear the steering gear box which sits farther back than in later cars.
Old Sep 30, 2007 | 06:33 AM
Oldsguy's Avatar
Past Administrator
Yeah, that old cast is weldable. It took me about a half hour to cut each one by hand with a hacksaw! Talk about getting tired...
atkinsom
May 29, 2013 06:39 PM
65OldsDelta88SuperRocket
Oct 27, 2011 09:16 PM
WasteOfMind00
Apr 19, 2007 01:30 AM
kylem4711
Mar 14, 2007 01:42 PM
