Exhaust manifold leaking
Went to custom exhaust guy "Lou's Custom Exhaust" and he fixes exhaust manifold leak (after having manifolds both sides skim cut) and replaces gasket. One month later drivers side leaking and he says it's the "head" it's not flat and gasket won't seal it. Not sure if this guy is right so I buy a "copper gasket" and have him install it and now it's still leaking but in a different spot. I say if it's the head it would leak in the same spot any advice out there? Trying to get the 455 to purr again help!!!!!
While I've never had an issue sealing the manifold to the head, I've had really good luck with Walker Acousti/Seal (P/N 35959). It's available from RockAuto as well as auto parts stores (in the US, anyway). Most of the high-temp silicone sealers aren't rated for continuous use at exhaust port temps.
exhaust leak help!
unfortunately you went to the wrong shop,these chain shops don't usually have people experienced in older cars let alone oldsmobiles. of course they claim to be experts and you would like to believe them. i am back from vacation so if you still want me to straighten that out for you call me.i can install the dual system they told you couldn't be put on your car also.it sucks to miss convertible top down time in new england because the season is not long enough so i feel your frustration. jim
Hey Jim thanks for the reply. I will say the guy from Lou's is a standup guy he called back and found a gasket he said would work and installed it and did not charge me for it very professional...Lou's Custom Exhaust got the job done!
Once convertible season whines down I still want the duals so I will be in touch Jim
Hey wr1970 if I had an infinite amount of money I guess I would have had the heads removed and skimmed cut. But the real world is the gasket route was much cheaper and removing the heads could also lead to other problems so yes went with the gasket route which I am willing to bet is not uncommon. So yes I say the guy is a professional because he stood behind his work the leak is fixed and I know not wat u consider "professional" but $ dictates how deep the problem can be fixed too
Suggestion
http://catalog.remflex.com/OLDSMOBIL...T_p/11-002.htm
Try these. I have used them to seal leaking headers and exhaust manifolds with great success. Just used a set on Sunday on my 72 W-30. Good to be leak free again.
2blu442
Mar 7, 2014 06:09 PM
atkinsom
May 29, 2013 06:39 PM
