Exhaust Manifold Bolts/Bolt-Locks
Old Dec 16, 2022 | 04:48 PM
F-85 4-4-2's Avatar
I need some education. Stock exhaust manifolds for a '66 400.
Fusick sells exhaust manifold bolt/washer sets for $36.50 and bolt-locks for $7.50 each, both for 1964-81. So $66.50 + shipping.
Inline Tube, aka Motor City Super Cars, has this set for $34.95, free shipping, but only for 1968-72? Wouldn't it work on stock manifolds a '66 400?
68-69-70-71-72 442 W-30 W-31 Exhaust Manifold Locks and Bolts Stainless Steel | eBay
Old Dec 17, 2022 | 06:53 AM
442Harv's Avatar
Not a 66 expert, but did 66 use the locks? Maybe that is why they are not listed for 66, but the one you showed should work. Also, I never use them, and never had a problem with bolts coming loose.
Old Dec 18, 2022 | 06:24 AM
jensenracing77's Avatar
They will work for all those years the same but there could be something that makes them slightly different between one year and another for originality reasons.
Old Dec 18, 2022 | 08:46 AM
66-3X2 442's Avatar
I believe the exhaust manifold bolts are the same as the bellhousing/automatic transmission mounting bolts. The 66's did use the lock tabs. You can buy OEM bolts here
https://www.amkproducts.com/about/
Old Dec 18, 2022 | 09:18 AM
Most vendors assume that Oldsmobile only built cars between 1968 and 1972.
mclark68442
May 28, 2021 08:50 AM
DocAS
Feb 9, 2015 10:15 AM
The Stickman
Jul 12, 2014 11:13 PM
my71olds
Apr 28, 2013 09:20 PM
Southern_Hospitality
Nov 6, 2011 08:03 AM
