Excess oil in Heads
Old Jun 1, 2009 | 04:22 PM
442 Guatemala's Avatar
Excess oil in Heads
Hello, After 3 months dealing with my oil pressure problem, now Im having 50 of oil pressure in idle when the car is cold and 20-25 idle when the car is in 175 degrees.
Now im having another problem: I have excess of oil in my heads, they are getting full of oil, specially the co-pilot side, in this side the oil is leaking from the breather. I install new Baffles, and I stop the leaking in the valve covers, but now im having problem with my breather. If I take out the breather I can see the oil coming out with pressure, so I dont know what is happening now.
I install a new High volume High pressure oil pump, I install new push rods (that I bought from mondello) and they supposed to be restricted, but Im not really sure, im going to check on that. To help draining the Heads I drill on each head a 1/2 inch hole, then I drill another 2 holes in the block, and connect the heads with the block with 2 hoses to help draining the oil.
I have more leaking problems when the car is cold. Im using now 15w 40 oil because my clearances are too tight, but Im not sure is changing to 20w 50 will help my leaking problem?
my Heads are B code.
What else I can do, or what else I need to check to solve this problem?? is that common on olds cars?
thanks for the help again guys
Alex
Old Jun 3, 2009 | 11:27 AM
88 coupe's Avatar
Junior Member
Originally Posted by Texascarnut
This sounds like a classic blow-by situation causing crankcase pressures to be so great oil cannot flow back through the heads and block to the sump ........
This is even funnier than the one about measuring heater hoses with vernier calipers.
Looks like I have another new sig line.
Norm
Old Jun 3, 2009 | 02:34 PM
Texascarnut's Avatar
Geezer
Norm
Look *** if you can't make a positive contribution why don't you just stay off the keyboard and go take your meds.
Obviously you've never seen crankcase pressures become great enough from blow-by to blow oil right out of the oil filler and if it will do that it will certainly be great enough to prevent oil from flowing back to the sump at least until there is no more oil to pump out and the darn engine seizes up.
Aside from that idiot, no one said measure the darn hose only the hose nipples on a year model having several sizes possible.
Old Jun 3, 2009 | 03:07 PM
jensenracing77's Avatar
i am not sure if it is your problem or not but i have seen an engine with so much blow by that it would blow the dip stick out of the engine. this was not an oldsmobile.
Old Jun 3, 2009 | 03:17 PM
MN71W30's Avatar
Yep,
I've seen breathers blow off, dip sticks hanging out, whatever it is it sounds bad.
Old Jun 3, 2009 | 04:07 PM
Oldsmaniac's Avatar
The valve covers look like maybe cheap aftermarket covers. There needs to be a baffle under where the breathers go and still they must be installed correctly and designed correctly. I would not assume right away that there is a serious engine problem untill research is done. I would assume that oil is being directed thru the baffle and out of the breather by some oddity. I would not assume that the area under the valve cover is being completely filled with oil and is being forced out of the breather......No this is not a common problem with old cars....
Old Jun 3, 2009 | 04:18 PM
88 coupe's Avatar
Junior Member
........ you've never seen crankcase pressures become great enough from blow-by to blow oil right out of the oil filler ........
You are right, I have not.
........ i have seen an engine with so much blow by that it would blow the dip stick out of the engine .........
Originally Posted by MN71W30
........ I've seen breathers blow off, dip sticks hanging out ........
So have I.
But the OP did not say anything about a dipstick or a breather.
Norm
Old Jun 3, 2009 | 04:22 PM
MN71W30's Avatar
I need guys like you on my speed dial.
But he did say with pressure. I guess we need to define it being oil or blowby.
Old Jun 3, 2009 | 04:26 PM
88 coupe's Avatar
Junior Member
........ I have excess of oil in my heads, they are getting full of oil, specially the co-pilot side ........
Take the cover off the co-pilot side, then run the engine and tell us where the oil is coming from.
I hope this is more helpful than the second post.
Norm
Old Jun 3, 2009 | 05:56 PM
So have I.
Norm
and the OP also did not say anything about heater hoses or vernier calipers.
Old Jun 3, 2009 | 07:06 PM
MN71W30's Avatar
It's a shame a guy can get belittled just trying to help out.
Maybe we need to hand out *** of the day awards. I know where I'd cast my vote.
Old Jun 3, 2009 | 08:09 PM
88 coupe's Avatar
Junior Member
No, I did.
This is even funnier than the one about measuring heater hoses with vernier calipers ........
If you would like to discuss it further, send me a PM.
Norm
Old Jun 3, 2009 | 08:17 PM
88 coupe's Avatar
Junior Member
It's a shame a guy can get belittled just trying to help out ........
"Helping out" does not include making a diagnosis without knowing the symptoms.
Norm
Old Jun 3, 2009 | 09:16 PM
MN71W30's Avatar
Norm
I have no interest in sending you a PM or recieving one from you.
I'm only here to learn a few things and maybe help a guy when my limited knowlege allows. If I am wrong I expect to be politley rebuked, is that too much to ask?. In the last 30 + years of working on cars I did manage to learn a few things.
There is a slight chance I may know something you don't.
Old Jun 4, 2009 | 02:00 AM
X2
Old Jun 4, 2009 | 02:58 AM
Rdrokit's Avatar
I had the same problem but I do not think my problem is the same as the OPs. I once bought a car that sat for many years and there was much sludge in the engine especially in the oil return passages in the heads. One bank was really bad as I pulled the valve cover off after shutting down the engine and about a quart of oil leaked out all over the exhaust manifold........the front cross member.....steering linkage........garage floor....a real mess.
Old Jun 4, 2009 | 06:30 AM
88 coupe's Avatar
Junior Member
Originally Posted by Rdrokit
........ I do not think my problem is the same as the OPs ........
Not likely, as his is a fresh rebuild.
Hi, many of you know in December i just rebuild my 400 engine for my 1966 442 ........
https://classicoldsmobile.com/forums...ure-again.html
Norm
Redog
Oct 20, 2015 03:29 PM
defiant1
Aug 26, 2011 09:45 AM
Railguy
Tech Editor's Desk
Jul 25, 2010 02:36 PM
86pontiac
Feb 17, 2010 11:24 AM
