Engine stall when idling for 15 min
Old Jun 21, 2020 | 12:22 PM
davertr's Avatar
I am having an issue with engine stalling after car idles for 15 min or so. Idle good and all of a sudden just dies and won't restart until I leave it for 15-20 min?
Old Jun 21, 2020 | 12:30 PM
Year? Engine specs? Stock or modified? Points or GM HEI or aftermarket electronic? Carb type? Fuel pump type? Etc, etc. There are only about a bazillion possible causes. Try and help us narrow it down.
Old Jun 21, 2020 | 12:36 PM
davertr's Avatar
It is a 1972 olds 442 455 4 brl. Auto trans stock engine
Old Jun 21, 2020 | 12:39 PM
So again, points in the distributor? And just to confirm, this is a factory built U-code 455 car and not a swap, right?
If so, I'd suggest looking at a coil that's going bad when it gets hot. I'd also put a fuel pressure gauge on the car and look at what's going on with fuel pressure when it stalls out.
Old Jun 21, 2020 | 12:40 PM
davertr's Avatar
As of now I have never had it stall while driving just started after ideling for a long time. Was recharging a/c and had it idling for a long time and than died thought it was a one off or because of a/c so ran it again today and idled without a/c on and again died from long idel
Old Jun 21, 2020 | 12:47 PM
davertr's Avatar
It is not a u code it is a w29 option I am told it is a 455 out of a 73 442 and yes has points
Old Jun 21, 2020 | 12:49 PM
tru-blue 442's Avatar
Old School Olds
If points and condensored distributor, the condenser can fail when up to temp and then work again when cooled off. I have had it happen. Just spit balling.
davertr's Avatar
Old Jun 21, 2020 | 01:41 PM
When was the last time it had a tune up or the tune gone over. I'd start there to see whats going on.
Old Jun 21, 2020 | 01:43 PM
davertr's Avatar
Just bought it a month or so ago so not sure according to previous owner was tuned up less than 1k miles ago. Has run well until now
Old Jun 21, 2020 | 02:04 PM
All the more reason to go over the tune. While your at it, its a good time to check/change all fluids, inspect the brakes, pack the wheel bearings, front end, front/rear suspension, fuel lines, and look at how old the tires are. I do this with every car I buy.
Old Jun 21, 2020 | 02:22 PM
davertr's Avatar
I already ordered new trans filter and gaskets and planned on doing fluid changes ect. Just weird that it was running good than all of a sudden but than again I haven't let car idle that long without driving it wonder if the air flow while driving has been keeping it cool enough not to show symptoms.
Old Jun 21, 2020 | 02:37 PM
Apparently your definition of "stock" engine is very different from mine... Look, I'm not trying to be a hardass here, but the mind reading thing still isn't working, and without having the car in front of us, it's REALLY difficult to provide you with useful troubleshooting information without knowing the EXACT configuration of the car and engine. From the engine photo, we can see that you have an aftermarket intake with some Qjet that may or may not be the right one for that engine. You have a PCV valve but a plug in the other valve cover so no way to actually ventilate the engine. You've got an aftermarket air cleaner. Apparently you don't have a fan shroud - what size radiator is in the car? How hot does it get when it stalls out? There are a LOT of potential causes, and the number goes up as the configuration departs from stock.
Old Jun 21, 2020 | 02:45 PM
davertr's Avatar
like I stated I just bought car about a month ago and i am not a 442 expert so I am not 100% sure what is stock or not. Its a quadrajet 4 brl carb and I have fan shroad but it needs replaced as has cracks in the plastic. I have driven the car a bunch since I got it and this has been first issue so just trying to figure it out. I am definitely a beginner so I apologize if I don't have all the answers
Old Jun 21, 2020 | 04:33 PM
davertr's Avatar
Just took it for a 20 min drive and no issues seems to be an issue with heat when idle and not moving when driving with air flow no issues
Old Jun 21, 2020 | 04:52 PM
66SportCoupe's Avatar
Agree with Joe P.
The engine is modified. It's not the one born with the car has open air cleaner and aluminum intake. The coil would be suspect and tune up next. Don't go off what got sold to you.
Old Jun 21, 2020 | 05:36 PM
If you can get an IR thermometer, monitor the temp of the ignition coil as the car sits at idle, and especially if it stalls.
Old Jun 21, 2020 | 06:49 PM
It also has a Holley / Mr Gasket mechanical fuel pump. While those are fairly good performance pumps, they are prone to cracking through the pump arm pin area, which can cause low fuel volume issues.
72cutlass408
Feb 25, 2020 07:02 PM
jaunty75
May 4, 2017 06:37 AM
Robert Zuijdam
Dec 18, 2013 12:29 AM
66ninetyeightls
Aug 23, 2010 12:24 AM
captjim
Jul 15, 2009 08:53 AM
