Engine paint
Old October 1st, 2012, 08:07 PM
Fastbrianman's Avatar
Engine paint
I am looking for who has the best deal on Oldsmobile blue engine paint for my 1970 455.
My motor is on the stand and this is the final step before she is ready to go in.
Thanks,
Brian
Fastbrianman is offline
Old October 2nd, 2012, 04:42 AM
507OLDS's Avatar
Fusick or Inline Tube has the correct 455 blue engine paint.Get at least 2 cans,to make sure you have enough.
507OLDS is offline
Old October 2nd, 2012, 05:16 AM
ah64pilot's Avatar
On my convertible engine I found the Fusik blue to be too light. The Supercars unlimited blue was the most accurate but it's not the cheapest. Watch out for pricing / oz. though, the Fusik paint looks cheaper but it's a 10 oz. can if I remember correctly. I had 2 cans and it was almost enough for 2 coats. Still, it's a little light. Check it out in my convertible build thread link in my signature.
ah64pilot is offline
Old October 2nd, 2012, 06:29 AM
Eightupman's Avatar
Do you want the best deal or the best match and quality?
Bill Hirsch has probably some of the best (correct) paint out there.
http://www.hirschauto.com/
John
Eightupman is offline
Old October 2nd, 2012, 06:53 AM
69'442's Avatar
Too bad they charge over $13 for shipping for a spray can.
69'442 is offline
Old October 2nd, 2012, 07:59 AM
Eightupman's Avatar
I don't think I paid that much shipping for two cans...but it was 6 months or more ago..
John
Old October 2nd, 2012, 08:45 AM
72 w29 all green's Avatar
Brian
I just went through this with my 455. The best "deal" might be NAPA if they still sell it. Tamraz had it for $13.99 a can, but Fusick, Hirsch, Inline Tube and Supercars Unlimited ranged from $16.50 -$18.99 a can but i don't remember how many ounces per can.
They all claim "perfect match" and there are opinions galore about what's correct. When I spoke to James Kryta of Inline Tube, he thinks there's more than one original shade of the 455 blue. The one he matched to was the slightly lighter of the original shade(s) of blue that he's apparently seen, and it was the one i bought. It looks VERY nice. I had NAPA paint on this engine in the early '90s and it was a very light metallic blue. I had the Supercars Unlimited paint after that and it was pretty dark. Good luck.
72 w29 all green is offline
Old October 2nd, 2012, 08:50 AM
Olds Dreamer
alek72us's Avatar
I have done the fusick, tamraz and parts place. tamraz is way to light. fuzick and parts place look alot alike but i get most complaments on the parts place one.
alek72us is offline
Old October 2nd, 2012, 09:04 AM
69'442's Avatar
Are there any that don't burn off the center of the intake. The fusick paint I bought did.
69'442 is offline
Old October 2nd, 2012, 09:17 AM
507OLDS's Avatar
I use the paint made by Bill Hirsch.I get it in the 1 quart can,and I brush it on.It's nice & thick,and dries without any brush marks.It has not burned off of my center ports as of yet,and it's been a good decade or more.I've had it on other engines for longer.Recently I did hear that it was no longer available,or Bill Hirsch is no longer in business.Does anyone know for sure?
I also think that there were many shades of the 455 blue.Every time they made a batch,the color probably varied each time.
507OLDS is offline
Old October 2nd, 2012, 10:26 AM
Eightupman's Avatar
http://www.hirschauto.com/ the website is still up.
Old October 3rd, 2012, 08:55 AM
Lance
ROCKET VAPOR's Avatar
The darker paint from Supercars Unlimited that ah64pilot and Joe spoke of matched the original paint on my engine.
ROCKET VAPOR is offline
Old October 3rd, 2012, 09:17 AM
Nilsson's Avatar
Hirsch has the best blue, their Bronze not so much so.
Supercars looks good also (Rocket Vapor) I would try that just to support Supercars.
Nilsson is offline
Old October 4th, 2012, 06:50 AM
76 Regency's Avatar
John
hey guys,
it seems like the Bill Hirsch website it still up and running so hopefully the business is still around. I really like the idea of brushing the paint on as the engine is in the car and it will take a lot of masking to make sure there's no overspray using spray cans. I think my biggest concern would be painting the valve covers or any other smooth surfaces that really do need to be sprayed. Is the Bill Hirsch paint easily sprayed for parts like that? If so, I'm thinking I could spray any parts I need to off the car, brush the block and then just do any touch ups on the bolts, etc if necessary. The pic I attached is from a related post and I think that color looks very good and close to the original. I think you probably get a thicker coat by brushing the paint as well.
What do you guys think?
thanks!
John
76 Regency is offline
Old October 4th, 2012, 07:12 AM
Nilsson's Avatar
Originally Posted by 76 Regency
hey guys,
thanks!
John
Masking is a pain. A trick I picked up is to use aluminum foil. You can cover just about anything you do not want painted cover it squeeze it so it stays in place, stuff in into nooks and crannies ect. There are still times you need to mask but it will be alot less.
Nilsson is offline
Old October 4th, 2012, 07:18 AM
507OLDS's Avatar
I've used the brush-on Hirsch paint on valave covers & oil pans,and it dried with no brush marks,nice & smooth.I think it could be sprayed,if desired,but I never tried it.
507OLDS is offline
Old October 4th, 2012, 07:20 AM
76 Regency's Avatar
good trick! I'll have to give that a shot. Thanks!
Old October 4th, 2012, 07:22 AM
76 Regency's Avatar
Thanks! The website says it can be sprayed. I'll give them a call and see what they say about reducing it, etc. I am really liking the idea of brushing the engine now that I think about it.
Thanks!
John
Old October 20th, 2012, 05:05 PM
Thanks for all the info. Great responses and a lot of usefull Ideas. That is what I love about this sight.
Thanks!
John
__________
I will be interested to see what you found out about this.
Thanks,
Brian
Old October 20th, 2012, 07:34 PM
johns59super88's Avatar
Herschel and spray
I used Hirsch paint with the engine out. I used a foam brush as suggested but wasn't happy. It seemed using a brush tended to leave too little paint on the texture of the cast parts. The tiny bumps had too little paint. I did the second coat with a preval spray kit. This was much better but I did have to use reducer. Bill Hirsch told me I didn't need reducer but the paint was so thick it just wouldn't work. I used about 25% reducer and the engine looks great. I'm not into actual spraying so the valve covers took a few coats with in between sanding but ended up really nice.
johns59super88 is offline
Old October 22nd, 2012, 06:26 PM
john paul's Avatar
455 blue
Thanks,
Brian
i got my paint from Brothers Automotive and it seemed to be an exact match to what was already on the engine. that was a few years ago but i can't remember what i paid for the three cans that i got from them. it is very durable, and has not burned of the engine in any location what so ever. i know a lot of our members don't like dealing with BAP, because of the poor service, but they are another source to consider. best of luck, hope you find a good match.
John Paul
john paul is offline
Jamesbo
Paint
June 13th, 2020 09:02 PM
jensenracing77
Paint
September 10th, 2014 02:33 PM
JpMotorsports
May 15th, 2014 07:08 AM
dlmsavings1
September 3rd, 2013 09:01 AM
805cut
May 3rd, 2012 08:11 PM
Quick Reply: Engine paint
