Engine mount frame pads.
Old Nov 20, 2021 | 08:09 PM
tkcutlass's Avatar
I am replacing my 350 with a 455 for my 70 cutlass vert project I know you just have to match the SBO frame pads and put the SBO mounts on the 455.
Is there any advantage to changing the frame pads to the BBO frame pads vs staying with SBO frame pads?
Old Nov 20, 2021 | 09:02 PM
edzolz's Avatar
Wish I had a dollar every time this is asked here. Do a search and you will get good info.
Old Nov 20, 2021 | 09:10 PM
66SportCoupe's Avatar
No benifits however just match what you have.
Old Nov 20, 2021 | 09:18 PM
tkcutlass's Avatar
Thank you that's what I was looking for
Old Nov 20, 2021 | 09:27 PM
2261 engine mount
Old Nov 21, 2021 | 06:59 AM
Just to provide full information, the 2328 mounts and matching frame pads DO tuck the mount a little lower and further inboard, under the pan rail. This MIGHT provide a skosch more clearance for headers. Note how much of the 2261 mount sits above the plane of the bolts to the block (red dotted line). The 2261 is completely outboard of the pan rail. The 2328 is tucked under the pan rail.
Old Nov 26, 2021 | 10:15 PM
I'll give Joe his thoughts on that however my 66 has small block pads and mounts and header clearance is almost a non issue other than steering rod.
Old Nov 27, 2021 | 05:37 AM
I wasn't suggesting it was necessary to use the 2328s, just that if one had a situation with large diameter headers, its an option that frees up a little more space. Obviously every 1966 came from the factory with the so-called "small block" mounts (2261s).
Chatt
Jan 22, 2023 01:27 PM
68442droptop
Apr 24, 2017 03:09 PM
Olds442redberet
Jan 18, 2017 10:35 AM
XTREMEGSXR
Jul 14, 2014 03:21 PM
HOODY
Jan 30, 2011 04:45 PM
