Engine lift plate & plugging engine dipstick hole
Old May 18, 2019 | 01:52 PM
BondAR's Avatar
Hey guys, I'll be running a canton oil pan and using their dipstick that threads into the boss on the sump instead of using the provision on the block on a 455 I'm slowly putting together. What are my options on plugging the hole on the block?
Also, when the time comes to swapping engines, are lift plates good to go for a 455 with aluminum intake (performer #2151) and aluminum heads?
Old May 18, 2019 | 03:04 PM
I use lift plates on everything, with a leveling rack if pulling the trans with it. For the hole, tap it and put a small threaded hex plug in it.
Old May 18, 2019 | 07:11 PM
Assuming the 5/16-18 threads in the intake are good, and there is sufficient thread engagement, the shear and tensile strength of a grade 5 bolt would be good enough to lift the entire car. A 5-600 pound engine would be no big deal. I recall Joe posting a article a few years ago with a the math to support the theory.
mattking
Sep 28, 2017 12:40 PM
TexasGunner
Aug 14, 2013 03:24 PM
my71olds
Apr 18, 2013 12:45 PM
adis
Dec 16, 2011 12:54 PM
Erinyes
Mar 20, 2011 05:54 PM
