Engine Install
Old Apr 29, 2013 | 07:12 AM
NightStalker's Avatar
Engine Install
I have a 455 (1969) which I want to drop in my 442 (1965).
Does anyone know if stock 1969 455 motor mounts will work, or will I need to find some 1965 400 motor mounts?
Do I have any other options?
Thanks in advance for your time and assistance.
NS
Old Apr 29, 2013 | 08:30 AM
NS
Search is your friend:
https://classicoldsmobile.com/forums...tion-list.html
Short answer, the 1965 cars used the same motor and frame mounts for the 330 and the 400. The 455 is externally identical to the 400. Use your existing frame mounts and Anchor P/N 2261 motor mounts (the stock ones for a 65). This is a bolt in. Be aware that you need the flywheel/flexplate from a 1968-up motor, since Olds changed the crank flange bolt pattern in 1968.
Old Apr 29, 2013 | 08:40 AM
Thanks for the help Joe.
NS
gunmetal71
Jul 6, 2015 02:58 PM
george landis
Apr 28, 2015 06:30 PM
2blu442
Nov 10, 2012 10:16 AM
805cut
May 3, 2012 08:11 PM
JoshF85
Mar 19, 2005 06:47 PM
