Engine ID Help
Engine ID Help
Hello everyone.
I am a proud new owner of a 1967 Cutlass Supreme, my first Olds.
The engine is not the original, and I am having a heck of a time identifying her.
Can someone please help me?
Thanks!
Thanks!
It is the 400 heads and the manifolds are the 400's as well.
Since it has an aftermarket intake I am going to say you may have a 1967 Cutlass Supreme with the Turnpike Cruiser(400 w/2bl Carb) option.
Is there a turbo400 trans?
Look for the tag on the trans.
There are numbers and a letter cast into the block just ahead of the thermostat housing, what are they?
Mike
Mike
As Mike said, you have a 1967 Olds 400, with a 10.25:1 compression ratio, which would have been sold with a 2bbl carb, so not a 4-4-2 motor, probably a Turnpike Cruiser motor.
Nothing wrong with having that mill in a '67.
Are you sure it's not original?
I looked closer at the engine pictures. I don't see the oil fill tube, it looks like the previous owner plugged it. Then it has the alternator bracket for an AC car but this is a non-AC car. It does look to me like something may have been swapped.
I'd encourage you to replace the oil fill tube. Several members here including myself have extras of these.
John
John
Mike
Mike
The number in front of the thermostat is 390925E
I can't seem to locate the tranny tag.
The transmission tag should be about an inch by 2½", on the right side of the transmission, just above the oil pan, and is usually completely covered with crud.
???? The E is the best of the *three* 400 engines. And correct for a '67 Turnpike Cruiser. Are you thinking about the '65 389298 B 400?
