EightballZ 455cui Rebuild
#81
Also, after the minor unpleasantness of the '30s and '40s, and, in the East, the inconveniences of the '50s through the '80s, the Germans have a slightly different view of privacy than we do.
For instance, they're one reason why Google now automatically blocks out car license plates on Google Maps. Over there, you can also get your whole house blocked out.
Oddly, they're still okay with being asked for your "papers," though.
Cultures evolve differently, which is why travel is still slightly fun (though less so every year - the first time that my cell phone rang in Venice in 2000, and it was just a friend who didn't know I was travelling, it totally freaked me out. You've got to go pretty far to feel like you've gotten away these days).
#85
But Venice is actually just sitting there on top of millions of gallons of sewage, which is fancifully referred to as "the lagoon."
Paris at least has les egouts, which take the sewage somewhere else.
#86
Very true,
I went to zurich for the first time this summer, It blew my mind.
Thousands of helplessly beautiful women who the locals are too shy to talk to.
Who get easily scared when you try to talk to them whilst double-fisting two Molson X's and a hockey t-shirt
Sigh.
Sigh.
#88
hey...
so the guy from the machine shop told me that the block only needs a re-hone and the crankshaft can be polished..no need for grinding it.
good news so far...
this is my shopping list...what do you think? (only rotating assembly)
- FelPro Rear Main Seal Ford 460cui FEL-BS40032
- ARP Main Bolt Kit 185-5001
- Clevite Camshaft Bearings SH1354S
- Clevite Main Bearings MS804P
- Sealed Power Rod Bearings 8-3345P
- Keith Black Piston and Ring Kit KB277KTM-STD
- Comp Cams Timing Set 2113
- Eagle H-Beam Connecting Rods 6735O3D
- Scat Balancer D-80022
...estimated CR 10,25:1..wanted to go with these babies but couldnt find them in standard bore size
good news so far...
#92
hey guys..i'm curious about the clearances (mains, rods, cylinder to wall etc.) ..what do you recommend? (street/strip use)
Deck Clearance with the H-beam rods and the IC886 pistons calculated at: -0.015
i iordered the IC886 pistons...not the KB's i mentioned before
i know the machine shop needs to clear the block since i bought h-beam eagle connecting rods....anything else to consider?
oh yeah...and what about the deck height?
i'm planning to mount pro comp heads and want true 10,25:1 CR. don't know about the head gasket...better use a thicker one or the thinnest available?
heres what the calc. says ..i used that cometic 0.027" gasket
#94
yesterday the machine shop started working on the block..
so the next question is...what about the heads?
would like to mount a pair of aluminium heads..not sure if procomp or edelbrock.
what would you say? out of the box or a little customisation like other than stock valves, springs, porting etc.?
http://www.mondellotwister.com/edelhds.html
#95
homecoming...after a 5 hour trip with a rented 2013 Audi A6
after 4 weeks the machine shop managed to finish the engine.
it has new pistons, rings, bearings, rods, rehone, rebore...and crank got balanced.
now i have to wait for all the small parts from summit and the heads and cam from cutlassefi
hope to start assembly by the end of february...1st drive in second week of april..i can hardly wait!!!
#99
Every single piston is backwards - exhaust valves are toward the center of the block on Olds, hence the relatively narrow exhaust manifold.
However, so long as all of the pistons / bores are the same size, he should be able to swap front 2 / rear 2 on each side and come out alright.
#100
are you sure??..check the link
https://www.uempistons.com/installat...stallation.pdf
P.S.:
seems right...damn it
http://static.summitracing.com/globa...L-60515_BK.jpg
P.S.:
#101
Yes, E heads:
Time to free some space in the living room, get a beer and have a little fun.
#102
Yup. Sorry.
Here's the illustration from your link:
And here's a photo I just took in my barn, with two heads lined up, showing the intake and exhaust ports - you can see how the ports line up with their respective valves:
edit:
Ha Ha, I did the dumb thing and photographed them from the sides, instead of photographing the valves, like NOP did:
edit:
#105
yup its wrong I did the same thing when i put mine in first, then I looked at the heads when i was getting ready to put them on and realized the sheet was wrong(some nice words came out of me after that). Nothing like practicing taking a whole set of pistons out and putting them in a couple of times
#107
one question before i start to switch the pistons and rods ...what about the balance?
isnt that totally off then?
or maybe he did a good job and every piston and rod weighs the same now...i hope he did..was not cheap
#111
little progress....i hope this time the position of the pistons is correct
i also installed the oilpump, pickup, freeze plugs, head studs and torque converter
now i need to wait for the heads and cam ... waiting is the hardest part
what do you guys think...how important is that 3rd nut which connects the rear oil deflector to one of the main caps? (see pic)
i think i stripped the thread on both the nut and the stud ... the other ones are fine.
oil pan mounted for dust protection...
next time i can install the head gaskets and prepare the block for painting
P.S.: note the license plate of that VW bus
#114
...i really hate wire-brushing !!
at least i got a nice cigar for the evening
mounted the old heads so i could clean the intake on the engine stand
#117
as you know..i'm going to mount a set of edelbrock aftermarket heads.
since one of the choke tubes broke while tearing down the engine i wonder if its a good idea to do a electric choke conversion??
as far as i know the heat crossover is blocked anyway so there's no need for choke tubes
oh and as you can see i installed the ARP head stud kit but what am i gonna do with the bolts you can see in the picture?
i need them to mount the alternator and A/C bracket i guess...and one is necessary for the "hot"-light
#118
Well, seeing as how you didn't really need the ARP bolts in the first place, I'd say just use your normal head bolts in those two positions.
And, No, I do not know whether they expand in a different way when hot, though I don't believe they do.
#119
some progress....
i still hate wirebrushing..but the results are pretty sweet
mounted the oil filter only for protection from dust...as eric said...they are junk, right?
these are 3 or 4 coats of bill hirsch engine enamel
