Edelbrock performer intake plumbing
Old Feb 10, 2013 | 08:29 AM
mhouston44's Avatar
I am in the process of putting my engine back into my car. It has been about 15 months since i took it apart and i upgraded from a stock cast 455 intake to the edelbrock performer.
I have noticed a few differences in the intake manifolds and for the life of me i cannot remember how i took this stuff apart. I have a Quadrajet going onto the Edelbrock performer manifold. Does anyone out there have a plumbing diagram for this combination or maybe just a picture so i can see what goes where all from the carb to manifold, and distributor to manifold?
I also have the original air intake that i would like to use unless my new setup is too tall for the hood. I need to know where those hoses from the OAI air intake hook into the engine as well. Any pictures would be greatly appreciated.
Old Feb 19, 2013 | 10:15 AM
Do you have the CSM for your car? It shows the routing for the vacuum lines. What year is this? I'm assuming it's a 442 since you're describing OAI components.
Old Feb 19, 2013 | 11:22 AM
timothypaul's Avatar
I plumbed both the vacuum modulator as well as the power brakes direct to manifold vacuum ports. That was the biggest issue I had. I am not using an OAI setup yet, but everything else was pretty simple. The vacuum advance on the distributor went to a port on the quad.
My biggest headache was more the brackets for the power steering pump, A/C, etc.
Old Feb 19, 2013 | 11:33 AM
see if these help
http://ephesians525.org/intake1.jpg
http://ephesians525.org/intake2.jpg
GothamCity
Feb 16, 2024 03:30 AM
69CutlassAlex
Jul 30, 2013 08:18 AM
70Cutlass_408
Jun 24, 2011 07:55 AM
agtw31
Jan 30, 2009 06:43 AM
blue72regency
Oct 27, 2007 09:47 PM
