Edelbrock O4B Intake Manifold Question
Old Dec 27, 2010 | 06:34 AM
69442's Avatar
I just bought a NOS Edelbrock O4B intake manifold for my '72 455. I remember reading that the threaded hole on the passenger side for the AC bracket does not properly line up. Can anyone confirm if this is true? If so, any experience with fabrication? Thank you, Bob
Old Dec 28, 2010 | 12:59 PM
dc2x4drvr's Avatar
On my O4B intake, I had no problem with the A/C bracket, lining up, on the other hand, most Torkers require modifying the bracket to fit.
Old Dec 28, 2010 | 03:58 PM
64Rocket's Avatar
I also heard that the "HEI" dist has problems
Gene
Old Dec 28, 2010 | 04:14 PM
dc2x4drvr's Avatar
Glad you brought that up, I had to "clearance" the back of the intake runner to clear my MSD ready to Run distributor, which is just slightly thicker at the base than a stock Olds distributor. My advice would be to dry fit everything prior to getting out the rtv..
Old Dec 29, 2010 | 09:47 AM
69442's Avatar
Thanks for the responses. I am currently running a Pertronix set-up, so HEI is not a concern. I was just hoping not to have to deal with A/C bracket issues.
DennisG.
Mar 19, 2012 09:54 AM
DennisG.
Feb 16, 2012 10:07 AM
skryla
Apr 1, 2011 11:58 PM
69442
Dec 13, 2010 05:16 AM
skryla
Apr 22, 2010 08:49 AM
