Early Quadrajet
Old Apr 22, 2017 | 03:49 PM
bw1339's Avatar
Early Quadrajet
Hello,
I'm looking at the QJ in my '66 Toronado. These don't have the conventional secondary pull-off. I always assumed that the arm/piston connected to the secondaries were exposed to engine vacuum, so it would function the same way.
Today, with the engine running, I pushed on the secondaries flap and there was no resistance other than the return spring, whereas with my later QJs, I would be fighting engine vacuum via the pull-off. Is this normal?
Thanks.
(photo from ebay)
Old Apr 22, 2017 | 08:22 PM
Quadrajet Power's Avatar
That is normal for the 65/66 Quadrajets. This dampener system was then changed to the vacuum release and the spring tension.
Old Apr 23, 2017 | 03:50 AM
bw1339's Avatar
Thank you.
auto_editor
Dec 20, 2010 11:24 PM
tiparosa
Feb 8, 2008 06:57 PM
bingo
Apr 8, 2007 05:14 PM
bigbrian
Jan 9, 2007 12:11 PM
1965442
Sep 9, 2006 04:12 PM
