do these numbers mean anything?
I dont remember seeing all these numbers on the last block I went through. Do they mean anything worth knowing?
bottom of block, rear side under starter, 3145.
bottom of block, opposite starter near oil filter adapter, 2.
the F on side of block.
back of block next to distributor, 2, 283, cfd.
rear of block where bellhousing/flywheel goes, 68 f4.
front of block underneath head, if bolted on. 39m605828
![](http://i1279.photobucket.com/albums/y536/young_olds/cutlass/IMG_0232_zpsc73273be.jpg)
thanks
thanks
Well, this one matters. You have a 455 from a 1969 Lansing-built Olds. The fact that the VIN derivative sequence number is above 600,000 tells us that the block came from a Toronado originally, since Toro sequence numbers started with 600,000 in the 1969 model year.
39M605828 = partial VIN# from 11/68 built 1969 Toronado
3 = Oldsmobile
9 = 1969
M = Lansing, MI assembly plant
605828 = VIN sequence (of the Toronado the engine is from)
F = large visual identifier of a casting # 396021 455 block ('68-'72)
283 = casting date - 283rd day of year (Thursday, October 10, 1968)
CFD = Central Foundry Division (GM's casting plants)
3 = Oldsmobile
9 = 1969
Every casting made there (and there were *lots* for all of GM) had a casting drawing and a machining drawing *at least*. Are they all gone?
