Do choke springs wear out?
Old Feb 12, 2011 | 08:38 PM
gearheads78's Avatar
car guy
I am working on a 66 442 right now and the choke spring seams to be very slow to curl up and pull the choke open. There is no binding and it looks to be hooked up right.
Old Feb 12, 2011 | 09:17 PM
Rickman48's Avatar
Yes, metal fatigues with age and use - it's a cheap and easy replacement.
You could even switch to an electric choke, with a little more money and effort, but much nicer results!
Old Feb 15, 2011 | 02:42 AM
Yellowstatue's Avatar
It's not a cheap replacement and also hard to find
Old Feb 15, 2011 | 05:57 AM
Rickman48's Avatar
If the spring is intact, you might check and see if the tube from the manifold is clogged, or if it's the type that bolts on the intake manifold, the heat passage in the manifold itself might be clogged!
Old Feb 15, 2011 | 07:35 AM
You all need to go back and read the original post. This is a 1966 442 with the divorced choke. There are no tubes to clog up and as noted, replacements are NOT cheap.
Old Feb 15, 2011 | 10:32 AM
Rickman48's Avatar
Which is why I included possibe clogging of the crossover passage - which heats the spring!
Don't know if the spring can open slow unless it's not getting hot fast enough!
Even partially clogged could slow it down!
I know I've spent up to an hour 'unclogging' manifolds, as even hot tanking won't get the baked carbon, soot and oil out!!
Old Feb 15, 2011 | 10:37 AM
OK, sorry. I read your response as clogs in the tubes for the hot air integral choke. On the other hand, I've never seen an intake crossover that was clogged, either.
Old Feb 15, 2011 | 03:32 PM
BlackGold's Avatar
Yes, choke coil springs do wear out. I don't know if it's the metals changing characteristics (losing their "spring") or corrosion gumming things up. But my experience is they lose their range of motion. That is, for the same change in temperature, an old spring will move less than a new one.
Old Feb 15, 2011 | 03:45 PM
car guy
I checked it with a heat gun and it does seem to open pretty quick. Idling in the driveway it does not seem to open but just driving around a few blocks it was wide open.
Old Feb 15, 2011 | 11:25 PM
Rickman48's Avatar
Is the 'heat riser' still on the car, and functioning correctly?
That'd help a ton, and the reason it's there.
Old Feb 16, 2011 | 04:16 AM
Destructor's Avatar
The hot air intake as stated previously is very important for smooth winter operation. Long after fuel injection ruled the roads I was driving my 72 Eldo with Q jet in temperatures down to zero with no problems starting or warming up. It had the coil spring mounted over the crossover and a functioning heat riser.
Jetstar 88
Oct 19, 2011 09:55 PM
Swede98
Drivetrain/Differentials
19
Sep 21, 2011 12:09 PM
Harmon
Paint
Aug 3, 2011 06:40 PM
gearheads78
May 19, 2011 09:32 AM
Wilson05
Suspension & Handling
May 12, 2009 10:04 AM
