distributor mods
Old Oct 20, 2009 | 08:27 PM
sethj78's Avatar
distributor mods
I was told I should take the vacuum advance off my HEI if I want proper curve or more power, something like that I got distracted and didn't catch everything he was saying. Has anyone ever ran their dist with out the vacuum advance. How about any other mods, any special olds techniques?
Old Oct 22, 2009 | 06:20 PM
cutlassefi's Avatar
For a street car, you really need one. If anything an adjustable one would be even better.
Old Oct 22, 2009 | 06:36 PM
442scotty's Avatar
I did not like the way the HEI was working on my 455...could not get it set up correctly so I ordered one from DUI ...gave them my engine/cam and vehicle specs and they custom made one...Only cost about $300... What a difference!!! Money well spent...car now runs awesome...flaweless...the only thing I had to do was add a shim(plastic gasket) because the shaft was bottoming out...
Old Oct 23, 2009 | 03:53 AM
70 cutlass s's Avatar
You need a vacuum advance for a street car. I know the set which your talking about not a good idea. That's more for drag racing. In a street car it would be hard to start. You could change your curve kit. There a lot of aftermarket parts to go in the HEI.
Old Oct 23, 2009 | 04:08 AM
Nilsson's Avatar
I do not run a vacuum advance at this time. I run 10 degrees initial timing and have no problems with starting, detonation ect. Gas mileage I am sure would be better with a vacuum advance, otherwise the car runs perfect. Currently running a Pertonix to keep the stock look.
Just for the record I am going to install a new advance sometime in the near future to see what happens.
Engine 68 400, 4 speed, 4:33 gear.
Old Oct 23, 2009 | 04:23 AM
Nilsson's Avatar
I also run a DUI in my 69 Cougar, it is a great setup and I wouldn't think of using anything else if I were to upgrade.
Old Oct 23, 2009 | 05:48 AM
I put a Summit HEI distributor in my 71 98. It is essentially stock except is has an adjustable vacuum advance and "heavy duty" parts (whatever that means). I am very happy with it. I put it in, and set it to the instructions and it runs well. It could use some more tweaking but I like it that it was ready to go out of the box.
Old Oct 23, 2009 | 11:58 PM
sethj78's Avatar
Hey guys thanks! U gave me some stuff to check out when I get this 455 put together. This dui your talkin bout, do they have a web site (I'm sure they do) whats the address...never mind I'll google it. Would there b a particular set up that is unique to olds?? Curve, vac setting, ect. anything I sould know about
Old Oct 24, 2009 | 06:11 AM
442scotty's Avatar
DUI http://www.performacedistributors.com or Davis Unified Ignition. They will built it to suit your engine specs and vehicle specs...Check out the site. You will see what I mean.
Old Oct 24, 2009 | 06:13 AM
442scotty's Avatar
If I could spell I would be dangerous...http://www.performancedistributors.com
Old Oct 24, 2009 | 11:14 AM
The Stickman's Avatar
I am really surprised no one has mentioned either the Mallory Unilite or the MSD distributors. At present I am running the Mallory and love it. I noticed an improvement right away. I also have a Billet MSD without vacuum advance that will be going in, and then the Mallory will go on the wife's car.
Old Oct 24, 2009 | 05:14 PM
mugzilla's Avatar
is Fast Enough ...
I went one grade lighter than stock on both springs and weights. Saved all parts ...
Old Oct 24, 2009 | 05:55 PM
442scotty's Avatar
What was nice about the DUI unit is that calibrated to your specific needs...takes the guesswork/trial and error out of equation. I was never really sure if my HEI was working the way it should for my application. My mind is at ease now. Im sure they could dial in any distributor not just one of their own if asked.
Tangovino
Mar 14, 2009 08:09 PM
kevin442
Site Help
Feb 22, 2009 05:48 PM
m_tanner_75
Dec 28, 2008 02:06 PM
olds69er
Apr 14, 2008 06:45 PM
<George>
Drivetrain/Differentials
Jul 12, 2004 11:00 AM
