Dipstick Tube Install
Old Apr 28, 2022 | 04:44 PM
oletrux's Avatar
Well, the 403 to 455 swap was going pretty well. Starter in and cables tethered out of the way, long tube headers installed...............then came the dipstick tube. Can't see very much, not much room to work down there, but I managed to stab it into the block. Right up to the 'bubbles'. Then comes the problem.........how in the world do you seat it so it's tight? Thinking about trying to slightly crush the 'bubbles', and add some engine oil or grease to help it along. Any other remedies??
Thx.
Old Apr 28, 2022 | 05:51 PM
66SportCoupe's Avatar
Take a block of wood and keep going til they're in the block
Old Apr 28, 2022 | 06:45 PM
RetroRanger's Avatar
72 Olds CS
is it a GM tube or aftermarket, the spectra tube i used had the flare a little larger than GM and needed to be filed down slightly to fit in the block.
Old Apr 29, 2022 | 07:25 AM
Every aftermarket or repro tube I've seen is too larger in diameter at the two beads that go into the block. I've filed them down to match the OEM tube, which typically means removing about 0.010" from each bead. After doing that it goes in just like factory.
Old Apr 30, 2022 | 10:32 AM
oletrux's Avatar
Well, I did file the beads slightly, then added a bit of grease, and used a block of wood to help as I tapped it to get started. I had removed the starter, so it was possible to access the flange on the tube from underneath. I fabricated a nut to fit around the tube, welded a small piece of round stock to it. I used a small clamp to keep the tool in place then used the slide hammer from my stud welder kit to tap it down into the block. The angle of the rod to the nut was nearly straight, but I must have bent it during removal............
Worked pretty well.
Thanks for the tips, guys.
Old May 2, 2022 | 08:25 PM
Gerald Nickels's Avatar
I always file then install a bolt in tube it works for me then hit it hard it will go in,
Old May 3, 2022 | 04:29 AM
deadeyejedi's Avatar
x2
tcarroll
Oct 23, 2014 09:37 PM
Stevec
Oct 27, 2012 07:20 PM
Stevec
May 17, 2012 06:13 PM
defiant1
Apr 30, 2011 08:41 AM
Mongoose
Dec 3, 2009 09:09 AM
