Diff. between Sealed Power & Melling High-Volume Oil Pumps
Old Apr 14, 2017 | 03:56 AM
STLCRZY's Avatar
Guys whats the difference between the Sealed Power & Melling High-Volume Oil Pumps below:
https://www.summitracing.com/int/par...203v/overview/
https://www.summitracing.com/int/par...2fhv/overview/
see that the Sealed power pick up
have a larger Tube Diameter (in): 0.750 in.
that the melling pick up
https://www.summitracing.com/int/par...fhvs/overview/
Tube Diameter (in): 0.625 in.
so which one to chose?
We plan to shim it a little bit.
Old Apr 14, 2017 | 05:27 AM
I may be mistaken, but I believe the only difference is the price.
If you were in the US, I would suggest ordering both and then returning one, and I would bet you get two of the exact same pump and pickup.
As for the pickup tubing diameter, those photos are exactly the same, and I think the diameter is the same on both, no matter what it says.
There may be someone here who has ordered both and can tell you with certainty.
Also, note that the high volume pump will only pump more volume through the engine if the engine has room for that much oil (looser clearances, especially when very hot), but it will place a higher load on the engine all the time, as the excess oil is wasted back into the pan, thus stealing an extra horsepower or two, compared to a "regular" pump.
This is not to say that I think you should not use a high volume pump (I use one myself, but it is on an older engine), only that you should understand the good and bad points of it before choosing it.
Old Apr 14, 2017 | 06:16 AM
Kennybill's Avatar
Check out Rock Auto, prices are better.
Old Apr 14, 2017 | 06:56 AM
Very true, and they do ship internationally.
Old Apr 14, 2017 | 07:51 AM
cutlassefi's Avatar
Most likely when you get the Sealed Power pump it'll have "Melling" cast into the housing. They're basically the same.
Old Apr 14, 2017 | 09:37 AM
STLCRZY's Avatar
Thank you brothers !!
brownbomber77
Dec 26, 2016 03:45 PM
Cpriester123
Aug 15, 2016 08:46 AM
86pontiac
Feb 17, 2010 11:24 AM
68conv455
Dec 26, 2007 07:29 AM
Joel n
Jan 12, 2007 03:34 PM
