Decode 455 Motor
Correct, those are GA heads, which were only used in the 1972 model year. The VIN derivative stamp will tell you the year of the block. That Offy intake is not your best choice for performance. If you can't hear it run, $250-500 is the max, and I'd err on the low side. If the pistons are stock, they have soup bowl sized dishes. The fact that it's been open to the elements for who knows how long says that you assume it's a core.
Joseph Miller
Dec 6, 2020 05:57 PM
