Crank wont rotate.
Old Jun 13, 2018 | 01:45 PM
67Rocket's Avatar
Crank wont rotate.
After installing a new set of Clevite MS 804P std main bearings, I cant get the crank to rotate. Main caps are only snug, I double checked the part numbers and the bearings are supposed to standard. This is a 400 E block. Any suggestions? Thanks to all.
Old Jun 13, 2018 | 04:45 PM
67Rocket's Avatar
Update, the crank will rotate if only cap 1 is snug, if I snug any of the other caps the crank wont rotate. I checked the bearings and they are stamped std. Any help appreciated.
Old Jun 13, 2018 | 05:21 PM
Can you measure them and confirm they are the correct size?
Old Jun 13, 2018 | 06:10 PM
BillK's Avatar
Are you using a rope rear main seal ? If so try it without the seal and see how it feels. Are you sure you have all of the bearings in the correct positions ?
Old Jun 13, 2018 | 06:43 PM
67Rocket's Avatar
Yes I am using rope seal, is there any alternative? Even with the cap with the seal loose when I snug any other cap the crank wont rotate. The bearings are installed correctly, Thanks
Old Jun 13, 2018 | 06:45 PM
67Rocket's Avatar
I have no way to measure the bearings but they are stamped std. Thx
Old Jun 13, 2018 | 07:24 PM
BillK's Avatar
Before you do anything else, remove the rope seal completely then reinstall the crankshaft and torque all the caps and see how it turns. Use 10w30 oil, not the thick sticky assembly lube. That way you will get a feel for how the crankshaft turns with no drag on it.
If it turns fine that way then you can either reinstall the rope seal or get a rubber one. I am pretty sure that BOP has them.
If the crank does not turn freely without the seal in place then you have other problems that are going to be hard to address over the internet
Old Jun 13, 2018 | 07:44 PM
cherokeepeople's Avatar
are the caps all in the correct location??if it will not turn with just the rear cap snug i would say under size bearings.
Old Jun 13, 2018 | 09:01 PM
steverw's Avatar
Why was the motor rebuilt in the first place? Did it have spun main bearings? Did the crank get turned and did the main bearing journals get checked for round and did they get turned? Did the block get align bored? Sounds like it may need it. I had this problem on the first motor i ever rebuilt, it was a 67 E block 400. I had spun the mains in it, didnt know it. When i went to install the crank, just barely tighten the main caps would lock up the crank. Had it alignbored and all was good. But then it needed an under size timing chain.
Just a thought.
Old Jun 13, 2018 | 09:15 PM
RandyS's Avatar
If the rope seal is causing the problem, suggest you use a neoprene seal from a Ford 460. Your local auto parts store sells them.
Old Jun 14, 2018 | 02:35 AM
rustyroger's Avatar
'87 Delta 88 Royale
You are installing the caps the right way round and in the order they came off?.
Roger.
Old Jun 14, 2018 | 04:25 AM
cutlassefi's Avatar
Roger.
They’re all numbered and go tang to tang.
And they don’t make “undersized” chain sets, how could they? They still have the same number of links.
The answer is that the sprockets are slightly oversized, tightening the slack in the chain.
Old Jun 14, 2018 | 05:42 AM
BillK's Avatar
Originally Posted by RandyS
If the rope seal is causing the problem.....
Rope seals, when installed correctly, put a lot of drag on the crankshaft until they have run some. If you are not familiar with this then you could think you have a bearing problem when actually everything is fine. That is why I suggested trying the crank without the seal first.
Old Jun 14, 2018 | 05:49 AM
67Rocket's Avatar
I will remove the rope seal and see what happens. Thanks everybody
Old Jun 14, 2018 | 04:56 PM
67Rocket's Avatar
The rope seal was the issue, I am going to try the seal from the 460 ford. Thanks everyone.
Old Jun 14, 2018 | 05:36 PM
OLDSter Ralph's Avatar
I thought I read that someone suggested a dab of RTV where the seal halves join, when assembling. This was to keep oil from seeping out.
Old Jun 14, 2018 | 07:39 PM
Yes, and I remember reading to offset the halves so the ends aren't flush with the bearing cap/block mating surfaces.
Old Jun 14, 2018 | 07:50 PM
yup we always put just a dab of rtv on the outer edge of the rope.and had good luck with it.especially if it was done in the car with a sneaky pete.
Old Jun 14, 2018 | 08:04 PM
Thanks, I forgot that part.
Old Jun 15, 2018 | 09:21 AM
Kennybill's Avatar
Check out Bill Travado's YouTube videos on putting together an Oldsmobile engine.
Rocketbrian
Mar 21, 2019 08:45 PM
NotDads442
May 16, 2018 03:13 PM
foo
Oct 16, 2013 05:30 PM
greenslade
May 2, 2011 07:14 PM
The_Jeremiah
Jan 7, 2008 11:34 AM
