coolin it down
Stock is fine. But you could try a lower temp thermostat. You could try a high flow water pump. Imo it's over kill if you engine is stone stock then no need. I run the water pump for cars with a towing package so it's considered a hd water pump. Temp drop was very small not work the 45 is spent.
I'll just say this when I lowerd my t stat from a stock 190 to 165 the cap that was on there was not sufficent enough to hold the psi. Don't remember why but a 16 lb cap worked in my scenario.
Pull the block plugs when you flush it and pull the stat out and force water in from every port just to stir up the settled crud so it comes out. Use a 180* high flow stat and you should be set. No need to go any further for a stock setup. If it works well then let it be!
Kickin' It Oldschool
Yea I'm going to clean the whole system out really well, It's probably never been done, I should have done this when I put in the new water pump when I first bought the car..
Thanks guys!!!!!!! =)
Oh btw, is it okay to block off my tranny lines from the radiator and run them to a tranny cooler instead? This way the transmission can stay cooler with its own radiator?
Anything I can do to keep temps down will surely lengthen the life of this car or any car for that matter.
I don't hot rod the car ......but I don't drive like Grandpa either. NO offense to my elders here~!!!!!
Engines are designed to run around 180 degrees, overcooling can be as bad as running too hot for engine life, and may hurt throttle response if it's too cold.
Roger.
455for30y
June 27th, 2007 12:58 AM
dcastine
August 10th, 2006 12:31 PM
