Connecting Rod Issue
Old Feb 20, 2023 | 05:06 PM
ben442's Avatar
455, Eagle H beam rods - part no. CRS673503D
The two photos below show where the No 1 rod, just installed, is making contact with the bottom of the cylinder wall edge on the inboard side of the engine.
One photo shows the rotation one way, the other is the other direction of rotation.
Would it be reasonable, or the correct action, to take a burr and grind off enough of the bottom edge of the cylinder wall for the rod to pass?
If so how much room or clearance should I give it?
Or is there another solution?
Old Feb 20, 2023 | 07:17 PM
68post's Avatar
Yes, and that's the only solution. I believe .060" is the minimum, but please verify.
Old Feb 21, 2023 | 05:47 AM
32redman's Avatar
Here you go
Block Clearance for H-Beams - ClassicOldsmobile.com
Old Feb 21, 2023 | 06:07 AM
cutlassefi's Avatar
Yes you’ll need to grind the block there. Next time you might want to consider the Scat rods instead. They don’t require block clearancing.
Old Feb 21, 2023 | 02:07 PM
ben442's Avatar
Wow, I not alone.
Thank You.
Old Feb 22, 2023 | 07:06 AM
chadman's Avatar
.060 is the rule of thumb but you can get away with less. I have run .020 counterweight to piston pin boss clearance with no evidence of contact after running. It wouldn't be my target number but it works.
Old Feb 22, 2023 | 07:22 AM
68post's Avatar
Thanks for verifying that Chad, I'd bet the 455 block cylinders squirm around enough to stay on the higher side of safety and I can see where other applications, or areas, could be tighter also.
I'd like to see the side by side difference btw the Scat and Eagle rods. Should be enough for a measurable diff in big end weight too.
Old Feb 23, 2023 | 11:34 AM
ben442's Avatar
This weekend I plan on grinding the block where needed and was wondering is there a specific total amount I should aim for.
Am I looking to grind away 1/8" or 1/4"?
Just looking for a starting point from someone who has done it.
Old Mar 18, 2023 | 08:28 PM
Saturn71's Avatar
Does anyone know what the SCAT rod weight is in comparison to the Eagle H-beams? I know that the Eagle weight is about 795 grams per rod.
Old Mar 18, 2023 | 08:59 PM
gs72's Avatar
72Cutlass S
.060” is roughly 1/16”.
Old Mar 19, 2023 | 09:22 AM
ben442's Avatar
complete, worked out great.
Old Sep 3, 2023 | 02:52 PM
mrdroptop2018's Avatar
Is there a I beam or H beam that doesn’t need to have the block clearanced? Stock stroke. Thanks
Old Sep 3, 2023 | 04:32 PM
cutlassefi's Avatar
Yes, as previously mentioned, Scats.
Old Sep 3, 2023 | 05:11 PM
I thought I read that but wasn’t sure. Thank you sir.
boese1978
Mar 8, 2016 03:49 PM
805cut
Jun 11, 2012 05:06 AM
craftsman1956
Suspension & Handling
Jul 16, 2010 09:56 PM
mb197942
Sep 5, 2008 08:47 AM
