Connecting Rod Bolt ID
Old Oct 20, 2008 | 08:36 AM
Stborden's Avatar
The bolts have a large N on the center with 12 point nuts. Anybody know the brand? I'm trying to decide if I should upgrade to ARP or if I can use the ones in there now but I have no idea who makes em...
Old Oct 20, 2008 | 12:10 PM
Run to Rund's Avatar
Stock bolts have a torque spec of 42 ft lb with oil. ARP are only about $60 and you torque them to 50 with the super slippery ARP grease. ARP are around 50 % stronger, a good upgrade so long as you get the big ends refinished with them installed.
Old Oct 31, 2008 | 05:34 PM
geckonz08's Avatar
ARP are around 50 % stronger, a good upgrade so long as you get the big ends refinished with them installed.[/quote]
U mean when you upgrade to ARP that the big ends should be re-ground or polished ??sorry just not certain what you are saying here --mind it is early and babysitting the grandson is sapping
mike
Old Oct 31, 2008 | 05:46 PM
64Rocket's Avatar
Yes, when you change to ARP bolts it is a very good idea to have the rods big end resized. The clamping power of the ARP bolt is so much better. You also need to do the same when you change to ARP main brg studs.
Gene
jvock6
Jun 17, 2012 10:27 AM
Al2011
Sep 19, 2011 04:50 PM
Seff
Aug 20, 2011 04:52 AM
SPEEDROCKET
Oct 25, 2010 06:42 PM
jensenracing77
Jun 1, 2009 05:59 PM
