Clutch Z bar mount
Old Oct 20, 2021 | 08:24 AM
REO442's Avatar
Lightbulb Clutch Z bar mount
Getting ready to specify to machine shop operations I require to spec out the 455 block. I need the measurements of the bolt hole, on the left side of the block to insert the pivot bolt for the clutch z bar. I want the option to use 4-speed trans with this engine. I may have read about this previously in the forum, can anyone come up with the location measurements and size? Thanks
Old Oct 20, 2021 | 08:48 AM
Oldsmaniac's Avatar
So you have a 1974 up 455 without the threaded hole for Z bar stud?
Old Oct 22, 2021 | 09:19 AM
REO442's Avatar
Thumbs up Patr number Identification and application
This is the 455 block I have to work with. Wanting engineering drawing specs for the threaded hole in the left side of the block for the Z bar mounting stud. Thanks for the input and support.
Old Oct 22, 2021 | 09:39 AM
Oldsmaniac's Avatar
You block should already have the provision for the z bar ball stud.... I only see an F...with no a....
Old Oct 22, 2021 | 03:36 PM
RetroRanger's Avatar
72 Olds CS
https://classicoldsmobile.com/forums...o-trans-62401/
this thread has some good pics of the z bar setup
Old Oct 25, 2021 | 09:41 AM
BillK's Avatar
Here is a picture of one of the blocks I have here. The hole is 1/2" x 13 thread size. If for some reason your block does not have the hole drilled let me know and I will try to get some measurements for you.
Darkalley
May 6, 2020 08:14 PM
1968ragtop
54
Oct 2, 2015 09:43 AM
70cutlass
Aug 7, 2014 06:30 PM
mrteeser69
May 30, 2014 04:04 PM
montvaleplace
Oct 6, 2012 07:28 AM
