clutch spring
Old Jul 10, 2011 | 07:50 PM
1969 442 w30's Avatar
clutch spring
where can you hook the clutch spring if you don't have the hole for stud on your starter? Can you make a bracket from some where else or do you need to put stud on the starter? thanks
Old Jul 12, 2011 | 07:19 AM
507OLDS's Avatar
There's a hole in the frame,almost directly next to the starter area.I've done that a few times.
Old Jul 14, 2011 | 06:35 AM
clutch spring
Brian, Thanks for the reply. Since the time I asked this question, I did locate the stud hole. I just didn't know it was that high up. I was able to clear hole of silicon and screw stud in with out droping the started down. I'm moving closer to finishing this convertion with a few more odds and ends to do. I'm REALLY looking forward to driving it with the 4 speed!! thanks again,Michael
RandyS
Jul 6, 2021 07:45 PM
47 Convertible
Apr 3, 2014 07:56 AM
RandyS
Mar 8, 2014 05:07 AM
RandyS
Mar 11, 2013 09:41 PM
Dick T
Oct 8, 2012 03:31 PM
