Ch*vy Hemi-esque W43-ish engine
http://blog.hemmings.com/index.php/2...8s/?refer=news
Hmmmmmmm....
"While researching our recent story on the 50th anniversary of the Mark IV big-block Chevrolet V-8, we came across something odd, something we’d never seen before – and it appears not many other people had seen it before either. Two photos in the GM Media database that showed two experimental big-blocks that very well could have set the American high-performance scene on its ear, had they been developed: one of a single overhead-camshaft hemi-headed 427, another of a fuel-injected hemi-headed big-block with pushrods. Neither of the photos appear in any of our searches, and a few days of searching led only to vague mentions here and there about Zora Arkus-Duntov and Chevrolet taking a crack at single overhead-camshaft, double overhead-camshaft, and hemi-headed versions of both the big-block and small-block in the mid- to late 1960s. No photos, no links to direct sources, just mentions of old magazine articles. GM itself wasn’t able to provide much more information. Corvette historian and author Ken Kaiser shed a little more light on the engines in the photos; according to Ken, they depict 1966-1967 vintage big-blocks, and the work order number stamped into the hemi-headed engine – 28451-20-A – denotes the first (and likely only) engine of its kind. The blockoff plate on the single overhead-camshaft engine above suggests it was meant to carry a fuel injection system of some sort, possibly the same or similar to the one we see on the hemi-headed engine below. The triple-row timing chain above looks rather stout (and not nearly as long as the Ford SOHC 427′s seven-foot timing chain) and appears as though it would have resided under a cover that encompassed the entire front of the engine, though we don’t see in the photo any direct connection between the crankshaft and the camshafts, and we’d have to wonder whether the cover and the chain would interfere with the water pump. The shaft-mounted valvetrain appears fairly straightforward and those huge intake ports look like a direct shot into the combustion chamber. UPDATE: McGean pointed out that there is a direct connection between the crankshaft and camshaft – it’s just really hard to see those dark gears sunk into the front of the engine. He also points out that the entire plate behind the timing chain appears to bolt to the existing holes for the regular (OHV) Mark IV timing chain cover, which would indicate that this whole unit was designed to bolt on to an unmodified Mark IV block...."
Hmmmmmmm....
