Carb Question
You have two options. The quick and dirty way is to use a self-tapping oversize repair fitting. These are available from Dorman Products. Unfortunately, it's difficult to remove and reinstall these fittings to replace the filter without cutting new threads every time, so I usually remove the stock filter, install the fitting, and run an external inline filter. The second option is to have a helicoil installed. There are services that do this for Qjets if you don't want to pay for the helicoil kit.
joepenoso
Jul 19, 2013 12:44 PM
