Carb issues ( I THINK)
I just had my 455 rebuilt about 3 mouths ago and the stock motor only .30 over other than that bone stock. Car has not left my shop other than in the back yard ( no miles I was starting it weekly sometimes just to let it run. then it started running really ruff SO first thing I did was pulled a few plugs. Plugs looked ok but had a little black film on them put 8 new plugs in and still running a little ruff on top of a little black smoke. But motor cranks every time but a little ruff after new plugs so I talk to my engine builder he said carbuerator is louding up due to the ethanol in gas and not being driving. Do I need to replace the carbuerator or put a rebuilt kit on it oh yeah it is a edelbrock 650 carb I would like to have a qjet but I am worried about clearance. Oh I forgot to mention after tuneup I played with the ajusting screw on front of the carb still no success. I am clueless.
if it has an aftermarket fuel pump even stock replacements sometimes pump out more than the stock psi if your fuel pump is pumping out more than 5.5 psi that could be it but also i agree with cutlassfi check your settings i bought an edelbrock carb that had NO FUEL FLOATS man was i mad i had to take a part new carb
Last edited by coppercutlass; July 10th, 2011 at 02:43 PM. Reason: im a horrible speller
