Carb hoses help please.
Old Apr 1, 2023 | 05:28 AM
5998DownUnder's Avatar
Hi there,
Well I’m at the pointy end of getting the the Olds going and just struck a problem re the carb hoses.
My photos from eight years ago when I removed the Quadrajet to put a Holley on are on a hard drive we can no longer access.
My manual does not help me nor does Google.
I have ports on the carb that I cannot remember where they go to so any answers diagrams (mud maps appreciated) photos etc will be greatly appreciated.
Also:
1/ On my photos the screw driver indicates the port I need info on where that goes to.
2/ Where does the choke connect to?
3/ where does the Throttle Return go to and do I really need this?
Thank you.
Old Apr 1, 2023 | 07:33 AM
Supernice88's Avatar
Art S
#1. Tee brass fitting - the straight larger hose goes to power brake booster. The smaller goes to the fitting on top of the fuel pump.
#2. A solid tube goes directly into the manifold (presses right in).
#3. A short piece of vac line connects to a brass tee, another short piece of vac line connects to the tee and then to solid line of throttle check return and then a long vac line connects to the tee and then to the vacuum advance on distributer.
#4. A vac line goes from the other fitting on top of the fuel pump to (for mine it goes to the deluxe heater inside the dash, I used a red tube).
Old Apr 1, 2023 | 11:15 AM
OLDSter Ralph's Avatar
Originally Posted by 5998DownUnder
Hi there,
Also:
Thank you.
I f you are calling the carb in these pictures a Quadrajet, thats a mistake. You have a typical Rochester 4GC. I would think your 1959 Olds CSM should show the vacuum lines, choke and anything else.
Old Apr 2, 2023 | 02:43 AM
Thank you Supernice 88.
I’ve got that done now with your help.
Old Apr 2, 2023 | 05:43 AM
Oldzskool's Avatar
Is that Detroit diesel green on your engine?
Old Apr 2, 2023 | 12:10 PM
Art S
You're welcome.
Your engine and bay looks great. Looks like you'll be cruising soon.
Old Apr 2, 2023 | 07:28 PM
I just asked for “original factory colour” not sure if it is or not.
I have a pic of my new engine and my old engine cover to compare mind you the old engine covers not sure which one is closest to factory.
rickw30
May 18, 2025 02:07 PM
block727
Mar 26, 2023 06:20 PM
Jul 13, 2022 08:46 AM
69442murph
Nov 14, 2021 07:59 AM
BGVISTACRUISER
Oct 1, 2017 03:34 PM
