Carb Choke Heater tubes - loose or ???
So I'm replacing the Holly carb on my 75 H/O (with a quadrajet) and I noted the Heater tubes are loose in that plate that's attached to the exhaust manifold. Looking at Fusick, I can get a set from them but it seems these tubes are merely pressed into the plate and are not permanently attached? Is that right?
Thanks in advance
Thanks in advance
