Can I install T400 with manual trans crank?
Old June 10th, 2013 | 10:28 PM
shamusj's Avatar
Hi Guys,
I have 400 from my old '67 442- it has the manual transmission crank set up.
I'll be installing this motor in my '68 with t400...should i have any worries about mating these two together? Would love to get the gotchas cleared before I start.
Old June 11th, 2013 | 04:53 AM
tru-blue 442's Avatar
Old School Olds
Shouldn't be a problem.
You would need the flywheel and bolts
for an automatic trans, and good
to go I would think.
Old June 11th, 2013 | 05:00 AM
+1. Works fine.
Old June 11th, 2013 | 08:14 AM
BILL DEMMER's Avatar
Just the facts...
assuming it's an early 400...
be sure to get the flex plate that is correct for the early big blocks.
after that, you're golden.
bill
Old June 11th, 2013 | 08:42 AM
Mikes442's Avatar
I just changed my 4speed to a turbo 400 this weekend in my '67 with NO problems.
After going through all my flex plates I found out how to tell the difference between the 330-400-425 and the 350-400-455 flex plates.
Good for swap meeting.
The 330-400-425 on the counter weight, the piece of metal welded to the flex plate has 8 holes and is cut at about a 45 degree angle on each side.
The 350-400-455 on the counter weight, also has the 8 holes and is cut about square angle on each side.
If I can figure out pictures I will post the difference.
Mike
Old June 11th, 2013 | 09:25 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
wanta sell the 4 speed set up?
Old June 11th, 2013 | 10:33 AM
Mikes442's Avatar
How much of the set up you need?
Old June 11th, 2013 | 11:47 AM
doing the opposite of what your doing in a 68...auto to stick. Console to flywheel all of it.
dan2286
June 5th, 2016 02:05 PM
dads72
March 25th, 2015 04:12 AM
young olds
August 23rd, 2013 06:26 PM
brandon reynolds
April 10th, 2013 08:14 PM
Nor Cal Andy
March 29th, 2012 09:20 PM
