Can This Carb be Saved?
Old Jun 11, 2021 | 12:08 PM
oldsonharmont's Avatar
I found a used Quadrajet core for my application, but the seller says 'for parts only'. Everything seems to be there, but with some slight rust and corrosion around the base plate. Would this still make a suitable core for rebuilding? How bad is bad when it come to carb cores?
Thanks,
Old Jun 11, 2021 | 12:18 PM
Hard to tell without a picture. If you soak it in carburetor cleaner long enough to get the linkage moving it would probably work great after a rebuild.
Old Jun 17, 2021 | 10:43 AM
Amplitude's Avatar
I wouldn't soak it in carb cleaner. I asked Cliff Ruggles about that very topic and he said absolutely not. He just uses brake clean and brass brushes to get the worst of it off before the parts go into an ultrasonic cleaner. I used a diluted mixture of Simple Green HD and warm water to scrub mine down. Came out pretty good. If it's rusted an coroded to the point that the linkage won't even move, I would think some targeted PB blaster, and a few moderate heat cycles should break it free, then maybe a good soak in ATF, followed by a rinse with brake clean.
The question would be, is it the correct carb for your car? Is it actually worth seeking out a numbers matching carb?
Or are you looking for a carb for a performance build? That will determine whether or not it's actually worth it.
Actually, I use this equation
[(((purchase price / actual value) x (my estimate of the cost in parts + (2.5 x(100 x my estimated man hours))) Then take the square root of that and add it to my expected return in joy and increased satisfaction with the car after it's done) from that total I subtract my wife's anger and the days without sex squared].
Old Jun 17, 2021 | 06:12 PM
hurst68olds's Avatar
is the "for parts only" a cover your a$$ description on eBay - or did you actually speak to the carb owner
Old Nov 5, 2025 | 06:23 AM
RWK's Avatar
RWK
Ultrasonic works well, with simple green or other safe chems. We used acetone in one to clean molding residue from injection mold components and vents.
Old Nov 5, 2025 | 06:42 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Here is a video of a guy using muriatic acid to clean a carb.
Aviator
Nov 2, 2018 12:22 AM
tru-blue 442
Sep 25, 2016 10:53 AM
kirkwoodken
Sep 25, 2013 10:23 AM
jaymann
May 12, 2010 12:12 PM
Oldsguy
Jul 30, 2007 06:22 PM
