Cam thrust button clearance
Old Jun 19, 2021 | 01:14 PM
grannys442's Avatar
I’m using Dick miller brass thrust button set-up to limit forward cam walk. Hyd roller cam application.
I’m not using the .040 brass washer between cam and block ( there was no damage in the block).
Since I’m not using the brass washer, i have quite a bit of clearance between the brass button and timing cover (currently .050 without the a gasket on the timing cover).
There’s currently no washer between the fuel pump concentric and the dick miller bolt. Maybe i simply remover the dick miller bolt, place a washer on it, and reinstall. That will move the bolt and brass button forward a bit.
I’ve read that .004 is a reasonable amount of clearance between brass and timing cover.
I see no obvious reason not to install the cam bolt with a washer and the fuel pump concentric. But wanted to bounce it off ya’ll.
Thanks,
Adrian
Old Jun 19, 2021 | 02:00 PM
cutlassefi's Avatar
I wouldn’t do any less than that. And make sure you check it with the water pump installed on the front cover. It’ll change.
Old Jun 21, 2021 | 06:57 AM
oddball's Avatar
Yup, use washers to push the bolt forward.
I aim for something just under 10 thou. Basically want it to have movement (a good thunk back and forth), but not enough to say "wow, that cam is moving!"
Also remember the gasket when checking.
Brians1
Mar 16, 2019 06:06 AM
330jetstar
Apr 13, 2017 07:37 PM
Olds442redberet
Mar 5, 2013 04:28 PM
rkk69olds
Apr 7, 2012 04:14 PM
zodiacblueS
Sep 15, 2011 09:42 PM
