Cam question
Old Dec 19, 2008 | 12:15 PM
nonhog's Avatar
Registered car nut
Cam question
Anybody run a Engle sm20/22h cam for BBO ?
496 in.
512 ex.
266
274
Gross 310
320
110 lobe center
Cant read the rpm range on the engle site . I think it says 1800-5800 but not sure the "old" cam spec are really hard to read .
Old Dec 20, 2008 | 05:41 AM
cutlassefi's Avatar
Cam Question
I ran the one just below it (216/226 @ .050, .488/.496 lift) on a 350. Very mild, but that may have been because the cam wasn't to spec. It had less duration (6 degrees) and lift (.010 cam lift) than advertised. I know everybody thinks Engle makes the "best cams for an Oldsmobile", but I would argue that till the end of time. I went to a custom Erson Hydraulic Roller and wouldn't go back to anything else.
Old Dec 20, 2008 | 06:20 AM
88 coupe's Avatar
Junior Member
From an early Mondello catalog:
JM-20-22
Lift = .496”/.512”
Advertised duration = 266°/274°
Duration @ .050” = 226°/230°
Lobe centers = 110°
Type = Hydraulic
Applications = Semi-hot street cam with great power and torque.
RPM range = 1,400-6,000
Approximate idle = Semi-rough
Hi-stall torque converter = Yes
Head work and headers = Yes
3.41 or lower gears = No
Norm
Old Jul 6, 2009 | 03:09 PM
nonhog's Avatar
Registered car nut
Thanks for the reply's ! Would this cam need any parts to make it work due to lift/duration as in pushrods, rocker arms ? Sorry not trying to be lazy just not sure where to draw the line on what cam works and when.
10.25 pistons I believe
Does anybody run a cam similar ? Curious about "hot street" I know I know
to one guy its radical to another its not.
O.K. take it easy on me : Olds newby
Old Jul 6, 2009 | 03:37 PM
88 coupe's Avatar
Junior Member
Originally Posted by nonhog
........ Would this cam need any parts to make it work due to lift/duration as in pushrods, rocker arms ? ........
No.
Always use the springs (preferably new) that are recommended by the grinder.
Norm
Old Jul 6, 2009 | 03:39 PM
Nilsson's Avatar
I run the Engle 22/25H, gobs of torque and and a sweet melody at idle.
Old Jul 7, 2009 | 11:26 AM
nonhog's Avatar
Registered car nut
Great info in restoration forum ? Odd but good
https://classicoldsmobile.com/forums...dello-cam.html
grmchne78
Jun 25, 2015 06:23 PM
Oldsmaniac
Jun 20, 2014 05:44 AM
Uncle Hulka
Mar 12, 2014 03:41 PM
GoldOlds
Mar 16, 2008 06:58 PM
glb1948
Aug 23, 2006 08:10 AM
