Cam comments?
Old Oct 17, 2014 | 02:42 AM
cwb442's Avatar
Cam comments?
Hey everyone
Just wondering what you think of this cam for my build.
Custom Hyd. Flat Tappet 240/240 duration Int.536 Ex.536 Lsa 110.
468 cu. stock balanced rotating assembly/ n-crank
C heads ported big valve
1.6 roller rockers
Air gap dual plane intake
750 dp carb
9.5.1 cr
Old Oct 17, 2014 | 04:22 AM
cutlassefi's Avatar
Gear? Tranny?
Why such a small carb?
Old Oct 17, 2014 | 04:23 PM
rubeng442's Avatar
I think it will work well with your engine. 3.73 or 3.90 gears would have it hauling the mail. An 850 carb would be nice as well, but you can get away with the 750 for now.
Old Oct 17, 2014 | 06:02 PM
cutlassefi's Avatar
Your combination doesn't make sense. You're using an RPM intake, that's for higher rpms. But then conversely you're using a 750 (not enough with the RPM intake) and a single pattern cam. It should be one or the other.
Old Oct 18, 2014 | 09:27 AM
cwb442's Avatar
Thats why i was asking. Not going to dyno. So i should go with a bigger carb then. How about the converter any ideas? Before i spun a bearing it had unported j heads with a performer intake and a 670cfm street evenger and a comp cam 268h. It was dyno tested with that and i believe made 420 hp/ 515tq. Car ran best of 13.0 flat 1/4 mile on street tires. With my new setupand say a bigger carb any idea what type of gains i might be looking at. I got the heads very cheap and the flow data with them. Told the custom cam shop what i had and the cam i picked was one of three hyd. Flat tappets he recomended. I went with the middle one.
71 A-body 3700#
3.73 gears
Th-400
27" tires
Old Oct 18, 2014 | 11:03 AM
cutlassefi's Avatar
The RPM intake has a small plenum, you need at least an 850.
What are the flow numbers on the heads?
Interested to know what the other cam choices were as well.
Old Oct 18, 2014 | 11:23 AM
cwb442's Avatar
Intake 500 lift-266
Exhaust 500 lift-194
Int. 600 lift 278
Ex. 600 lift 200
Mark I'm not sure the full specs on the other cams but the lower one i believe was 236-238 duration and the higher one was like a 246 duration. Knowlton thunderhead did the heads out of MN so thats who i contacted for a cam. Told them my setup and they contacted cam shop and then got back to me with three options. Any idea what it might do for power. Also converter recomendations. Thanks
antweave
Paint
Jul 12, 2011 12:01 PM
help442onguam
Mar 24, 2011 07:31 AM
lshlsh2
Oct 18, 2010 05:52 AM
nelsontj
Jun 9, 2009 03:35 PM
