Block numbers on 455
Old Jan 13, 2014 | 06:03 PM
classicmuscle442's Avatar
Bought a '70 442, W30?, the machined pad on block has L3E with 8401y stamped underneath the L3E. The code by distributor is \ 120 /, stamped on blocks oil filter mount is 009-7-87, which is also stamped on the end of one of the F heads. The casting number by water pump is 396021FA. Car was built in December of '69, car has CA emissions and had a CA plate in trunk. Trying to figure out what this block was in or was it from a boat? Any help would be appreciated. Chris
Old Jan 13, 2014 | 06:20 PM
oldstata's Avatar
Justin
From my understanding the L means marine or industrial use so it could have been a water pump
Old Jan 13, 2014 | 06:22 PM
1964f-85's Avatar
L is for lancing
3 is for 1973
Old Jan 13, 2014 | 06:23 PM
Ok, that makes sense, any idea's on the 009-7-87?
Old Jan 13, 2014 | 06:29 PM
oldstata's Avatar
Justin
Originally Posted by 1964f-85
L is for lancing
3 is for 1973
I don't think so
On the pad it's a marine or industrial used motor
This one was a marine
Old Jan 13, 2014 | 06:30 PM
oldstata's Avatar
Justin
I am not sure date code ?
Old Jan 13, 2014 | 06:33 PM
I don't think so
That's exactly how the block is stamped.
Old Jan 13, 2014 | 06:39 PM
OLDSTATA, does your block have anything stamped by oil filter mount?
Old Jan 13, 2014 | 06:41 PM
oldstata's Avatar
Justin
Mine doesn't have the oil filler tube but it has the common block number 396021fa
Old Jan 13, 2014 | 06:48 PM
Oil FILTER mount on bottom end.
Old Jan 13, 2014 | 06:51 PM
oldstata's Avatar
Justin
A big F is all I can see I also checked my other two can't see any thing other on. Any of the three
Old Jan 13, 2014 | 06:56 PM
Thanks for your help, was thinking it might be another use besides car but could not find any info.
Old Jan 13, 2014 | 06:57 PM
oldstata's Avatar
Justin
Olds FAQ talks about the L blocks some maybe it will help it's been awhile for me
Old Jan 13, 2014 | 07:25 PM
Looked under FAQ for L blocks, did not see anything, Block does not seem like anything worth rebuilding, just wonder what the 009-7-87 stamping number was for? Possibly stamped when engine was rebuilt, but why the heads. Having heads redone and there going to take some work to reuse.
Old Jan 14, 2014 | 11:18 AM
L is for lancing
3 is for 1973
M is for LanSing (as in Michigan)
This is NOT an automotive VIN-derivative, so it is clearly not the original engine block. This was formerly an industrial or marine motor.
Old Jan 14, 2014 | 12:51 PM
4speed455's Avatar
Did marine/industrial engines get F heads? The OP said that the number stamped on the block was also stamped on one of the F heads. Maybe this was warranty short block and they swapped over the original top end?
Old Jan 14, 2014 | 01:19 PM
Pretty sure not. There would not have been any number stamped on the heads, either. Dealerships frequently didn't even bother to stamp the VIN derivative on a replacement block, so it's unlikely they would stamp the same number on the block and heads.
Old Jan 14, 2014 | 03:46 PM
Thanks for the info, any ideas about the stamped number 009-7-87? Anyone have a number stamped on the oil filter mount on engine block? Fortunately the car does have the OW trans and it matches the vin.
Old Jan 14, 2014 | 05:39 PM
oldstata's Avatar
Justin
I taking a guess but maybe a rebuilder stamped it ?
Old Jan 15, 2014 | 08:00 AM
That's one possibility.
Old Jan 15, 2014 | 09:30 AM
Octania's Avatar
Any chance these are E heads with part of the E ground away?
Let's see some photos of these stampings.
Old Jan 15, 2014 | 06:49 PM
Small cast numbers on heads are 404438, have to get in barn to get picture of stamped numbers.
Old Jan 19, 2014 | 09:35 AM
oldstata's Avatar
Justin
Here is the info from olds FAQ
Marine Blocks
The marine blocks I've found have the numbers crudely stamped (ie, not even), in a font size larger than that used for the VIN derivative, and there is a drill spot on the number pad. The stamped-in numbers are of a different size and font than that used on the factory-stamped motors and are not lined up very well.
On the block ID pad, where the ID numbers go (front drivers side), there is a number that begins with an "L". This strange "VIN derivative" (or engine unit number) number starting with L denotes a marine motor.
Old Jan 19, 2014 | 12:14 PM
Marine Blocks
Yes the L letter and the T are larger than the three in between, the row below the top row the 8401y is stamped "normaly", have to get a picture its buried in back of barn. It spun #7 rod bearing if I remember correctly, have to check pistons for overbore size.
Old Jan 19, 2014 | 12:40 PM
oldstata's Avatar
Justin
I would entertain a offer on a full rotating assembley from my marine motor all I would do is replace with better pistons
Old Jan 19, 2014 | 01:23 PM
Pictures of block below, F heads are on car, 009 stamp is either behind alternator bracket or passenger side against firewall. The 009 stamp on block matches the head. Chris
Old Jan 19, 2014 | 02:06 PM
Is the marine motor anything special over other 455's? Block I have is good and local engine builder said he could save crank by using Cheby rod on #7 rod that spun. Bought car with bad motor, when drained oil it came out like wet mud. Crank as I remember is a nodular (N) lettered unit.
Old Jan 19, 2014 | 02:09 PM
oldstata's Avatar
Justin
If it has the N keep it it's better than the one I have I got my marine motor cheap it was rebuilt but the guy didn't winterize it and the block froze and cracked I was keeping it but the motor I just disassembled has the N crank so I will be using it.
Old Jan 19, 2014 | 02:40 PM
lunaboy's Avatar
The Rocket Astronomer
I assume you know the 120 is the Julian build date of block. what year I am not sure, but by the the distributor there should be a casting digit. I believe , all 70 455s have a # 3 by the jullian date.
if you are looking for a replacement block with the correct build for your w30 I have a 311 block from a lan 70 442 M1 vin ...
Old Jan 19, 2014 | 03:11 PM
When I bought car I knew it was a 442 but was not sure it was W30, have since learned quite a bit about them, it has all the specific W30 stuff except carburetor. Built a '71 block figuring a lot of these original motors were flogged heavily and replaced. Texas is a long way to ship to MI, think I can find one in area? Thanks, Chris
Old Jan 20, 2014 | 06:56 PM
  #31
Octania's Avatar
I have some 1970 blocks, but mainly 88/ Toronado samples.
In MI, handy-ish
jawsmon
Jul 13, 2012 07:17 AM
JBishop
Jan 17, 2012 08:28 PM
bluecab
Apr 20, 2011 05:26 AM
BigBertha442
Jul 9, 2009 11:18 AM
tobipaint
Jul 11, 2007 10:48 AM
