Block ID, 425 w/o numbers?
Have been cleaning the block up a bit before it goes to the machine shop. It has no numbers, just two holes drilled where the numbers should be, It is a "D" casting. I have not measured bore or stroke to verify that it is a 425. Has anybody seen this before? Maybe a factory supplied short block?
I posted this on the TOA forum as well, but I thought the bigger audience over here might be able to help.
Thanks!
Thanks!
http://tech.classicoldsmobile.com/36.shtml
Block ID question
Oh, Yeah,
It is the right casting to be a 425, 389244D and it looks to have been in there a long time, as far as dimensions, I meant I haven't measured it for overbore or had it apart to check rod size.
I was more curious why there are no numbers where the "numbers matching" VIN sequence should be, like is that common to short block replacements, is it a previously stolen motor, Etc.
I don't care if the numbers match as I intend to build it as a driver, not a show car, I've had enough of that to last me.
If you still have them, check them out.
Oh, Yeah,
If those numbers next to the distributor follow suit with the 455 numbers,then that block was cast January 10th,1967,which would be the 4th year of production.You figure that they started casting the 425 in 1964,for the 1965 model year.Maybe I am totally wrong.
BigBertha442
July 9th, 2009 11:18 AM
TECH9TWISTA
April 24th, 2008 03:14 PM
