Big Block Olds 400/What's Your Opinion?
What's your opinion of the EARLY BBO 400? Do they make good street/strip motors? I'd like to put together a nice pump gas friendly BBO ("boulevard bruiser"). I've read the early 400's are more desireable. I have access to an early 400 ("E" block). Also, I read SBO W-31 flat top pistons fit early 400's.
Early 400 is a shadow of the 425 except for 1/8" smaller pistons. It has a forged crank and if it's a 67 442 block it has the 2.067" intake valves...Other years were 2.00".
350 pistons would require a .057 overbore.
Makes a fine street/strip engine.
Norm
X2. I have to agree. Simple logic is that with the 400 being a 425 with a smaller bore, and the 425s are more plentiful and not stock in any 442, there isn't any compelling reason to forgo the extra cubic inches.
Of course, then you will have merely a "lowly" 425, which as some have recently said is no substitute for a 455, but that is another matter...
Everywhere I checked for info on 1966 400/425 heads say they have 2.00 intakes including the 442's....1967 used 2.00 except for 442's which have 2.067.
And for the record, I have factory GM shop manuals.
Further proof is offered by the June '67 Olds Parts & Acc. Catalog that shows all '66-'67 442, Starfire, Toro, etc. have exactly the same intake valves.
Bear in mind that all ('60s, at least) shop manuals are published well in advance of production, and I can't think of a year that has more than the one early edition. Changes are generally covered by Service Bulletins.
'66 442s did indeed have 2.067 intakes. I'm sure the GM shop manuals you have are dated prior to actual '66 production. I'm guessing that they originally were slated to be 2.00, but were increased just prior to production. There is a mid-year 442 brochure that specifies the 2.067 for one source.
Starfires used small intake valves.
Henry
i bought a turnpike cruise option cutlass long time ago for parts and it had the 2brl 400, small valve B heads. i think you could also get the 400 in a vista cruiser with 2brl&thay also had 2.00" valves? i have some small valve B heads now that i picked up recently ,where would they be from?
There are small and big valve B heads ('66) and small and big valve C heads ('67-'69). *Generally* speaking, the 442s, and higher compression 400s, 425s and 455s like the Toros and Starfire motors got the larger valves. I'd have to go back to the books for exactly where the line is drawn from small to large, *but* there has "always" been some evidence that there was some infiltration of small valve heads on some large valve applications (and who knows, possibly the other way around). This would not have been a far fetched possibility, as there is no external identification for valve size. The only way to be sure is to measure, though some well trained eyes can look at the valves and/or the seats and tell.
While I do not have access to the books you have, I must respectfully disagree with big valves in Starfire engines based on personal experience.
I do think this is a specific area where there have been smaller valves found in applications that were *supposed* to have large valves as I previously said. So finding actual exceptions are certainly possible.
I know this has been the case in '65, but should not be the case in '66-'67.
http://www.realoldspower.com/phpBB2/...ic.php?t=24745
http://www.realoldspower.com/phpBB2/...663ef92dc5ddc9
I know I am talking about '66 Stafire engines here; while I understand that the Stafire engine option (if not the car!) was available in 1967, I'm not sure I have ever actually seen one nor do I know what the factory stated specs were.
jpaulwhite
June 26th, 2012 02:59 PM
