Need your opinion on heads choice please.
Old Nov 9, 2011 | 09:33 AM
Al2011's Avatar
For a hot street car what heads would be better.
Edelbrock 60519 brand new $1600. Or Ka heads ported and polished by Joe Mondello $800 used? The bottom end would be pretty much stock with a agressive but streetable cam and edelbrock performer manifold or maybe the edelbrock rpm air gap. Compression between 9.5 - 10.1. Also is there anything different about Ka heads being used in a car?
Old Nov 9, 2011 | 09:56 AM
507OLDS's Avatar
The Edelbrocks would still be better.
Old Nov 9, 2011 | 10:31 AM
Al2011's Avatar
Thanks for the reply. Do you have a link or part # for the cheapest rockers and rods that will work with the e-brocks? I guess best bang for the buck type thing. Thanks again..
Old Nov 9, 2011 | 10:36 AM
380 Racer's Avatar
The Edelbrocks like any aftermarket aluminum head, needs to be checked out before bolting on. A friend just bought a pair and the chambers varied from 77-81 ccs on one head. That head wasn't flat either. This probably wouldn't make much difference on the average street motor though.
Old Nov 9, 2011 | 12:23 PM
Rickman48's Avatar
I had posted about some new Mondello heads a little while back - maybe chinese, but would save a few bucks for a street motor! Includes intake, too.
Punch Mondello in the search area.
Old Nov 9, 2011 | 12:49 PM
cutlassefi's Avatar
They're from Procomp, just contact them directly, they'll put you in touch with one of their dealers.
Old Nov 9, 2011 | 12:52 PM
Run to Rund's Avatar
You may save money with the edelbrocks compared to fully working a set of irons (valve job, surfacing, guides, etc.). However, you can run stock rockers on irons, but need roller rockers and studs on the e-brocks. It also seems easier to seal iron heads to the block. As for flow, if it is a street engine and cam, you probably won't see much difference. If in a cold climate, remember the edelbrocks don't have heat risers.
Old Nov 9, 2011 | 01:39 PM
Al2011's Avatar
How would these heads compare to the edelbrock heads? They are much cheaper.
http://www.racingjunk.com/Heads/2344...num-heads.html
Old Nov 9, 2011 | 02:00 PM
cutlassefi's Avatar
Those are the Procomps I just spoke of.
Old Nov 9, 2011 | 02:31 PM
Al2011's Avatar
You're right I apoligize I missed that. how do you think these are compared to the e-brocks both out the box?
Old Nov 9, 2011 | 06:26 PM
Bernard Mondello Racing Engines has a thread on ROP and offers them in three stages of completeness, starting at $649.
Old Nov 9, 2011 | 06:40 PM
citcapp's Avatar
That's per each correct?
Old Nov 9, 2011 | 06:49 PM
Boldsmobile's Avatar
Old Nov 10, 2011 | 04:44 AM
cutlassefi's Avatar
No, a pair bare.
Old Nov 10, 2011 | 07:07 AM
citcapp's Avatar
I looked at the sales add for ROP members only. Great pricing, this might bring down the cost of the brock heads. I wonder if the fuel pump clears the procomp heads. I got kicked off ROP so I don't cualify for the special price. Don't know why I could not get a mod to answer me.
Old Nov 10, 2011 | 03:35 PM
380 Racer's Avatar
I bet if you talk to Benard, he would sell them to you for the same price.
Old Nov 10, 2011 | 04:17 PM
Al2011's Avatar
I'm new to this site. How do you get to ROP to see these heads. I've been searching all day.
Old Nov 10, 2011 | 04:32 PM
citcapp's Avatar
Look here
http://www.realoldspower.com/phpBB2/...ic.php?t=79326
Old Nov 10, 2011 | 04:33 PM
http://72.22.90.30/phpBB2/viewtopic.php?t=79326
Old Nov 17, 2011 | 10:03 AM
Texas Jim's Avatar
Texas Jim
I just read the post where the combustion chambers varried from 78cc to 81 cc in the same head and that the heads were not even flat. I must say, I'm not surprised. My brother and I have been purchasing Edelbrock equipment since the later part of the '60s, and back in '70 f/ example, a time I remember so well, when my brother had a '58 Corvette w/ a 327/365 in it, he bought an Edelbrock manifold. The finish on the manifold was nice and clean, w/ no seam showing/left trash on the surface that should have been ground off. In those days, the Edelbrock manifolds were very pretty looking and also performed well. I recently bought an Air Gap manifolod f/ my '81 Corvette. After opening the box, I called my brother back home and told him how dissatisfied I was w/ the finish on the manifold, so many places that should have been cleaned up but were just left, looking like a mess. I was pretty much bumbed out. The quality control department there at Edelbrock is hurting IMO. Where is the pride in the workmanship? I personally like things that run to also look good, and Edelbrock has forgotten to take care of their customers to do w/ their components not just performing well but looking good at the same time, and to do w/ the heads, not even being precise enough to maintain constant chamber size across the board. Come on, Edelbrock, you claim the old "made in the USA," how about making the good old USA look good w/ what you turn out, don't make us all look bad.
Old Nov 17, 2011 | 10:09 AM
Al2011's Avatar
So in your opinion would you get the procomp heads or the edelbrocks?
Old Nov 17, 2011 | 11:35 AM
cutlassefi's Avatar
What's your budget?
Imo the Procomp heads along with an Edelbrock Air gap RPM with a good 800-850 carb, 10.0:1 compression and the right cam will get you 450+hp and well over 500lbft of torque, yet still be very streetable.
Again jmo.
Old Nov 17, 2011 | 02:00 PM
Al2011's Avatar
What's your budget?
Again jmo.
I'm just doing it a step at a time. This weekend machine shop will eat up $700-1000. Then I will do the summit racing finance thing for a rebuild kit or maybe even piece a kit for myself about $600-1000 before end of this year. Then January (tax return)I should have my mind made up between edelbrock or procomp heads the Mondello worked ones, E-brock RPM Air Gap, and E-brock or holley 750 - 800 cfm carb, Hooker headers and misc. parts to dress up the 455. I will leave the cam choice for a reliable source. My compression should be 9.75 - 10.0 With 15cc dish KB pistons or maybe I may go forged because a friend of mine wants to install a nitro kit. If anyone has any machine shop tips or anything I may be missing let me know please.
Old Nov 17, 2011 | 03:39 PM
380 Racer's Avatar
Again jmo.
Mark......just curious, anybody running these heads on a running engine? Either on the street or down the track?
Old Nov 17, 2011 | 04:30 PM
cutlassefi's Avatar
Not that I know of but I bought a set that I hope will be on a SBO stroker before next summer.
Old Nov 17, 2011 | 06:34 PM
380 Racer's Avatar
OK.....thanks.
Bamfer
Nov 6, 2012 06:17 PM
jpaulwhite
Jun 26, 2012 02:59 PM
Al2011
Sep 3, 2011 08:23 AM
hazzmatte
Oct 13, 2010 06:19 PM
ddusty1
Drivetrain/Differentials
May 20, 2008 04:12 PM
